Re: SB race block cam tunnel machined wrong
[Re: 408Dust]
#2181828
10/24/16 10:58 PM
10/24/16 10:58 PM
Posts: 6,139 Melbourne , Australia
LA360
Or plug the lifter bores and re-machine them to 48*
The push rod geometry on the 9.2" deck 59* isn't pleasant
Alan Jones
[Re: scottb]
#2181964
10/25/16 03:21 AM
10/25/16 03:21 AM
Posts: 3,699 Newport, Mi
Evil Spirit
Newport, Mi
9.200 deck with 59 lifters Yep - got a new one on the shelf. Wallet has been trying to decide for about 10 years the best way to use it. I'll probably have more money fixing the cam and bearing issue than the rest of the motor. I can't really make the cubic inches I wanted to, either - I'll probably stay with a 3.79 stroke to keep a decent pin height and not pull the pistons out of the bottom of the block too far.
Free advice and worth every penny... Factory trained Slinky rewinder.........
[Re: 408Dust]
#2182025
10/25/16 10:43 AM
10/25/16 10:43 AM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
Why not have the tunnel machined and run 54,55 mm cam? Thats what I did. yes this I think would be best
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: P7 Engineering]
#2183298
10/26/16 09:52 PM
10/26/16 09:52 PM
Posts: 714 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
the 50MM is not a problem for comp cams to do (they have the size listed in their catalog 1.968). I would call and ask about the 59 degree angle. If it's not to big they might be able to do it. they also list round cores.
Joe
Without Data, you’re just another guy with an opinion.
#2183682
10/27/16 11:53 AM
10/27/16 11:53 AM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
ok, where do I get a 54/55 mm 59 degree cam from, other than a custom billet? If I am going to do a custom cam, then why not a 50 mm so I don't have to re-machine the tunnel? Right now I am told that it is a 6 month lead time to have one made. And I don't have 6 months. I think I would still move the lifter bores to 48 degree before I would do a custom cam, so then I get the benefit of the improved push-rod angle, for my effort. You get that cam from the same place you are going to get the 50mm, which will also be a non standard core custom grind. The larger core is always the best option from a cam standpoint. Larger equals stiffer. The last custom tool steel billet I had done, which was a couple months ago........took 3 weeks to get
