SB race block cam tunnel machined wrong #2181499
10/24/16 03:33 PM
10/24/16 03:33 PM
Pennsylvania
P
P7 Engineering Offline OP
P
Pennsylvania
I know there are some 59 degree race blocks that were incorrectly machined with a 50 mm cam tunnel. I am working on making a set of custom cam bearings to make this work. The trick has been getting a piece of 850 aluminum alloy to make them from. I had to have a foundry cast me a piece. I didn't know if anyone else out there has one of these blocks?
My 1974 2WD shortbed Chevy Truck build thread:
http://67-72chevytrucks.com/vboard/showthread.php?t=525098
Re: SB race block cam tunnel machined wrong [Re: P7 Engineering] #2181608
10/24/16 06:11 PM
10/24/16 06:11 PM
New Smyrna Beach FL
scottb Offline
scottb  Offline
New Smyrna Beach FL
9.200 deck with 59 lifters
Re: SB race block cam tunnel machined wrong [Re: P7 Engineering] #2181747
10/24/16 09:21 PM
10/24/16 09:21 PM
408Dust Offline
408Dust  Offline
Why not have the tunnel machined and run 54,55 mm cam? Thats what I did.
Re: SB race block cam tunnel machined wrong [Re: 408Dust] #2181828
10/24/16 10:58 PM
10/24/16 10:58 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
Or plug the lifter bores and re-machine them to 48*
The push rod geometry on the 9.2" deck 59* isn't pleasant
Alan Jones
Re: SB race block cam tunnel machined wrong [Re: P7 Engineering] #2181963
10/25/16 03:21 AM
10/25/16 03:21 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
....there is still a 9.20 deck 59 degree block in the parts system. It's in the Atlanta depot
Re: SB race block cam tunnel machined wrong [Re: scottb] #2181964
10/25/16 03:21 AM
10/25/16 03:21 AM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
Yep - got a new one on the shelf. Wallet has been trying to decide for about 10 years the best way to use it. I'll probably have more money fixing the cam and bearing issue than the rest of the motor. I can't really make the cubic inches I wanted to, either - I'll probably stay with a 3.79 stroke to keep a decent pin height and not pull the pistons out of the bottom of the block too far.
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: SB race block cam tunnel machined wrong [Re: 408Dust] #2182025
10/25/16 10:43 AM
10/25/16 10:43 AM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
yes this I think would be best
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: SB race block cam tunnel machined wrong [Re: P7 Engineering] #2182904
10/26/16 11:57 AM
10/26/16 11:57 AM
Pennsylvania
P
P
Pennsylvania
Ryan has plugged the lifter bores before, and re machined for 48 degree bores. But he said that would be a lot more work than making a set of cam bearings. I just finished the bearings. They were easier to make than re machining to 48 degree. Although I would agree that improving the push-rod angle might be worth the extra effort.
Re: SB race block cam tunnel machined wrong [Re: P7 Engineering] #2182915
10/26/16 12:27 PM
10/26/16 12:27 PM
Pennsylvania
P
P
Pennsylvania
ok, where do I get a 54/55 mm 59 degree cam from, other than a custom billet? If I am going to do a custom cam, then why not a 50 mm so I don't have to re-machine the tunnel? Right now I am told that it is a 6 month lead time to have one made. And I don't have 6 months. I think I would still move the lifter bores to 48 degree before I would do a custom cam, so then I get the benefit of the improved push-rod angle, for my effort.
Re: SB race block cam tunnel machined wrong [Re: P7 Engineering] #2183148
10/26/16 06:14 PM
10/26/16 06:14 PM
rpagan Offline
rpagan  Offline
Talk to Danny at predator cams. Good guy to deal with.
Re: SB race block cam tunnel machined wrong [Re: P7 Engineering] #2183272
10/26/16 09:36 PM
10/26/16 09:36 PM
408Dust Offline
408Dust  Offline
LSM 248-674-4967 I had one made for me in less then three weeks before the gators this year 54 mm. 9.200 59 degree buzz it pretty good with no issues.
Re: SB race block cam tunnel machined wrong [Re: P7 Engineering] #2183298
10/26/16 09:52 PM
10/26/16 09:52 PM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
the 50MM is not a problem for comp cams to do (they have the size listed in their catalog 1.968). I would call and ask about the 59 degree angle. If it's not to big they might be able to do it. they also list round cores.
Joe
Without Data, you’re just another guy with an opinion.
Re: SB race block cam tunnel machined wrong [Re: P7 Engineering] #2183405
10/26/16 11:24 PM
10/26/16 11:24 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
hehehe.... remember going through my babbit cam he77 a couple years ago when NOBODY had them. The R3 world is an interesting one smile
Re: SB race block cam tunnel machined wrong [Re: P7 Engineering] #2183437
10/26/16 11:49 PM
10/26/16 11:49 PM
East Brunswick New Jersey
N
NoFrills Offline
NoFrills  Offline
N
Did you make the spacers? I also have one of these blocks. If I remeber right one of the spacers would only be like .008 thick. I thought about pouring some out of babbitt and machineing the whole bearing.
Re: SB race block cam tunnel machined wrong [Re: P7 Engineering] #2183661
10/27/16 11:30 AM
10/27/16 11:30 AM
Pennsylvania
P
P
Pennsylvania
Re: SB race block cam tunnel machined wrong [Re: P7 Engineering] #2183667
10/27/16 11:42 AM
10/27/16 11:42 AM
Pennsylvania
P
P
Pennsylvania
Re: SB race block cam tunnel machined wrong [Re: P7 Engineering] #2183682
10/27/16 11:53 AM
10/27/16 11:53 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
You get that cam from the same place you are going to get the 50mm, which will also be a non standard core custom grind. The larger core is always the best option from a cam standpoint. Larger equals stiffer. The last custom tool steel billet I had done, which was a couple months ago........took 3 weeks to get
Re: SB race block cam tunnel machined wrong [Re: P7 Engineering] #2183799
10/27/16 02:52 PM
10/27/16 02:52 PM
Pennsylvania
P
P
Pennsylvania
Well, I know we could have gotten a custom cam made. We can argue about how long it would actually take. I am not building this motor, Ryan is. And he made the decision that he wants to be able to use an "off the shelf core" 59 degree cam, in this motor. So given that, here is what I did. I had a foundry cast me a piece of 850 aluminum alloy. In order to get the piece cast and shipped to me in the same week, I had to accept a raw piece like this with no core out the center or rough machining done prior.
Re: SB race block cam tunnel machined wrong [Re: P7 Engineering] #2183839
10/27/16 03:52 PM
10/27/16 03:52 PM
Pennsylvania
P
P
Pennsylvania
Starting rough turning....
Re: SB race block cam tunnel machined wrong [Re: P7 Engineering] #2183842
10/27/16 03:53 PM
10/27/16 03:53 PM
Pennsylvania
P
P
Pennsylvania
