Frost in trailer revisited #2180890
10/23/16 04:12 PM
10/23/16 04:12 PM
Anoka County, MN
Leigh Offline OP
Leigh  Offline OP
Anoka County, MN
Experimenting this winter, with a Maxxair vent. Looking for more airflow, and am hoping this will help.
Re: Frost in trailer revisited [Re: Leigh] #2180973
10/23/16 07:36 PM
10/23/16 07:36 PM
Ontario, Canada
Stanton Online content
Don't question me!
Stanton  Online Content
Don't question me!
Ontario, Canada
Here's the dilemma ... you can blow all the air you want through there BUT the outside air will warm up faster than anything you store in the trailer will SO the warm, humid outside air will condense when it contacts any cold surface or item in your trailer. The additional airflow could cause more condensation than no airflow at all. Other than a heater in the trailer I think you're fighting a losing battle.
Re: Frost in trailer revisited [Re: Stanton] #2181002
10/23/16 08:31 PM
10/23/16 08:31 PM
Anoka County, MN
Leigh Offline OP
Leigh  Offline OP
Anoka County, MN
Very sound thinking. Since it's not possible to heat it, maybe time for some kind of desiccant system?
Re: Frost in trailer revisited [Re: Leigh] #2181047
10/23/16 09:24 PM
10/23/16 09:24 PM
Can , Nova Scotia , Cape Breto...
caper Offline
caper  Offline
Bail hay spread out on the floor to suck up the moisture.
New best 10.18 , 1.40 60 ft 496 Scott Brown built, street driven 3600 lbs,654 hp , 653 ft tq
Re: Frost in trailer revisited [Re: Leigh] #2181120
10/23/16 11:05 PM
10/23/16 11:05 PM
Ontario, Canada
Don't question me!
Don't question me!
Ontario, Canada
What all are you storing in the trailer? If its just a car and I wanted to keep it protected I think I'd do this ...
Buy one of those large storage bags and drive the car in. Wait for a cold day when the humidity is low - middle of winter works - and then use a shop vac to suck the bag tight to the car. Seal the bag.
Now the only moisture to form on the car itself will be the minimal amount in the bag. Moisture in the outside air will condense on the outside of the bag, not on the car.
Just a thought.
Re: Frost in trailer revisited [Re: Stanton] #2181141
10/23/16 11:33 PM
10/23/16 11:33 PM
Ohio
lockjaw-express Offline
Ohio
I keep a ceramic cube heater in my trailer in the winter...works great!
I got mine from West Marine, and it has a tip over sensor, and thermostat. I set mine for 50 degrees, and no moisture!
Regards, Mark
Re: Frost in trailer revisited [Re: Leigh] #2181368
10/24/16 01:05 PM
10/24/16 01:05 PM
Renton Washington
Triple Threat Offline
Renton Washington
I use DampRid Hanging moisture absorbing bags in my racecar and trailer. They're easy to hang from rollbar tubes. You can watch them fill up with water over time. I've got a few friends who use them now as well. I've had much better luck with the bags over the tubs that they also sell.
Not sure how well they will work in an environment where its constantly frozen though.
Example:
https://www.amazon.com/dp/B00FZDOQEI/ref=twister_B017T17DVQ?_encoding=UTF8&th=1
$7.97 for 3 bags is a cheap experiment. They work great up here in the Pacific Northwest.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Frost in trailer revisited [Re: Leigh] #2181603
10/24/16 06:09 PM
10/24/16 06:09 PM
Las Vegas
Al_Alguire Online laugh2
Las Vegas
We live in the desert so no moisture issues. Problem solved come to the southwest smile
Re: Frost in trailer revisited [Re: Leigh] #2181642
10/24/16 07:13 PM
10/24/16 07:13 PM
Renton Washington
Renton Washington
Maryland isn't the southwest smile
-Dustin
Re: Frost in trailer revisited [Re: Leigh] #2189856
11/05/16 02:40 AM
11/05/16 02:40 AM
Central Ohio, USA
Bigbeep Offline
Bigbeep  Offline
Central Ohio, USA
But a small box fan in the trailer on low and close the door. Try it, the slow air flow does the job. Hope this helps. Beep
Re: Frost in trailer revisited [Re: Leigh] #2189857
11/05/16 02:41 AM
11/05/16 02:41 AM
Central Ohio, USA
Bigbeep Offline
Bigbeep  Offline
Central Ohio, USA
