1969 Dart GTS 340 Vert #2179141
10/20/16 02:00 PM
10/20/16 02:00 PM
Illinois
bltcuda1972 Offline OP
Illinois
Hello Everyone,
I just brought 69 Dart GTS 340 Vert, and just found out that freeze plugs got rust out so needed to replace them but I plan take motor out and clean it up and I notice there is 2 diff color blue and orange engine so also I plan to paint the engine.
Blue or orange which one is correct?
Brad
Re: 1969 Dart GTS 340 Vert [Re: bltcuda1972] #2179150
10/20/16 02:20 PM
10/20/16 02:20 PM
Cab_Burge Online work
Cab_Burge  Online Work
It probably depends on when it was assembled and at which plant, the fender tag has that information on the bottom line scope
The first five letters and numbers of the VIN tell you which car maker, model of the car, the year model and the sequence number of that car built that day scope That will be to the far right of the of the bottom line, if you want to list all the others numbers to the left of the VIN # maybe someone who knows can answer your question with that information accurately luck
Re: 1969 Dart GTS 340 Vert [Re: Cab_Burge] #2179154
10/20/16 02:24 PM
10/20/16 02:24 PM
Illinois
Illinois
ok I will check it out
thanks
Re: 1969 Dart GTS 340 Vert [Re: bltcuda1972] #2179161
10/20/16 02:35 PM
10/20/16 02:35 PM
Illinois
Illinois
Fender Tag
3rd line
R6 P6? W1 923 129513
4th line
E55 D32 LS27P9B149652
Re: 1969 Dart GTS 340 Vert [Re: bltcuda1972] #2179163
10/20/16 02:36 PM
10/20/16 02:36 PM
New York
rarefish Offline
rarefish  Offline
New York
This topic has been discussed a lot in the past. The argument for the 1969 340 engine color is usually whether the engines were all turquoise or were some of them painted blue. The fender tag never had engine colors on it. Here is a post from A-bodies Only.
http://www.forabodiesonly.com/mopar/threads/engine-color-1969-swinger-340.294072/
Re: 1969 Dart GTS 340 Vert [Re: rarefish] #2179171
10/20/16 02:49 PM
10/20/16 02:49 PM
Illinois
Illinois
I will paint turquoise.
Thank again
Brad
Re: 1969 Dart GTS 340 Vert [Re: bltcuda1972] #2179664
10/21/16 12:07 PM
10/21/16 12:07 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
JB Rhinehart, Realist
A-Body's RULE!
Re: 1969 Dart GTS 340 Vert [Re: Rhinodart] #2181544
10/24/16 04:43 PM
10/24/16 04:43 PM
Illinois
Illinois
it very helpful.
thanks Rhinodart
