440 with CH4B conversion from Eddy 750 to Holley/Quickfuel #2179116
10/20/16 01:18 PM
10/20/16 01:18 PM
MD
p d'ro Offline OP
p d'ro  Offline OP
MD
Hi,
My 440 has stock pistons, comp cams XE262 magnum cam, Eddy Performer heads, CH4B manifold, and stock HP exhaust manifolds, 2.5" exhaust with crossover. I want to swap the Eddy 1411 with either a Quickfuel or Holley and keep it relatively cheap. I see there is a lower cost Quickfuel VS, then a SS and Q. I really haven't had a Holley in 20 years and am not sure which Holley or Quickfuel would be best for my street cruiser. A little tuning is fine, but out of the box performance is what I prefer. Any ideas?
I have the stock finelines fuel lines/look and want to keep metal lines if possible. Does anyone have a recommendation for off the shelf lines from stock fuel pump to carb for this application. I can't find it..
Will the Holley/quickfuel fit on the CH4B or do I need an adapter?
Thanks, Pete
Re: 440 with CH4B conversion from Eddy 750 to Holley/Quickfuel [Re: p d'ro] #2179205
10/20/16 03:57 PM
10/20/16 03:57 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Your combo sounds like it could use the 750 Quickfuel VS carb but it looks like they only offer it with a dual feed line setup. I really like Quickfuel carbs for their adjustability features and the one I have ran almost perfect when I got it.
It will bolt directly to your intake with new Superformance gaskets. There are a few different styles of stock looking fuel lines for this manifold and carb combination. Just search Google images for "steel line from pump to carb 440 Mopar" I found a few images pulled from this site.
Gus beer
64 Plymouth Savoy
Dana 60
Re: 440 with CH4B conversion from Eddy 750 to Holley/Quickfuel [Re: p d'ro] #2179268
10/20/16 06:04 PM
10/20/16 06:04 PM
MD
p d'ro Offline OP
p d'ro  Offline OP
MD
Thanks Gus. I just think it is time with all of the $$ I have in the tuning kit, now extra squirters and going back in to thejets/rods. It is futile.
I was looking at this carb on Summit as a friend is running one on a 383 and is happy.
I am usually a google master finding stuff and I don't want to plumb my own lines as I will probably burn down my car,..
Re: 440 with CH4B conversion from Eddy 750 to Holley/Quickfuel [Re: p d'ro] #2179345
10/20/16 08:49 PM
10/20/16 08:49 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
The new Street Demon is available in 625 and 750. They have electric choke standard. On my 360, the plastic bowl version lowered the carb temp by a full 20* over the Holley it replaced. That was with the cross over blocked in both cases.
The Street Demons will fit both bolt patterns. And the tune in them is really on target for our street cars.
http://www.hotrod.com/articles/inside-the-new-street-demon-750-cfm-carburetor/
http://www.dodgecharger.com/forum/index.php?topic=112118.0
http://www.forabodiesonly.com/mopar/threads/got-my-new-street-demon-carb.349645/
Many, many more reports on Utube and Google.
Master, again and still
Re: 440 with CH4B conversion from Eddy 750 to Holley/Quickfuel [Re: DaveRS23] #2179380
10/20/16 09:24 PM
10/20/16 09:24 PM
MD
p d'ro Offline OP
p d'ro  Offline OP
MD
I hadn't considered those. My crossover is blocked due to the Performer heads, so that is good. I will first get my car out and see if the new squirter and accelerator pump helped at all. Then I will check prices of the carbs and the lines.'
One think I noticed is that the fuel line from the Quickfuel seems to go right over the distributor due to the angle of the inlets... I do not like that..
Re: 440 with CH4B conversion from Eddy 750 to Holley/Quickfuel [Re: p d'ro] #2179662
10/21/16 12:05 PM
10/21/16 12:05 PM
MD
p d'ro Offline OP
p d'ro  Offline OP
MD
I hate to impose, but can someone post an image of their quickfuel plumbed up to a stock pump with simple steel (not braided) lines, and minus the regulator. I have been online looking at every dual feed system possible, and am confused, as well as a little wigged out by the costs...
Re: 440 with CH4B conversion from Eddy 750 to Holley/Quickfuel [Re: p d'ro] #2179704
10/21/16 01:27 PM
10/21/16 01:27 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
Here's mine with a Holley. The fuel line goes around the dist but has caused no issues in 20 years:
Re: 440 with CH4B conversion from Eddy 750 to Holley/Quickfuel [Re: Dcuda69] #2179793
10/21/16 03:49 PM
10/21/16 03:49 PM
MD
p d'ro Offline OP
p d'ro  Offline OP
MD
Thanks. It looks good. What material is that black line going from the dual feed down to the pump? I want to avoid rubber..
Re: 440 with CH4B conversion from Eddy 750 to Holley/Quickfuel [Re: p d'ro] #2179944
10/21/16 08:17 PM
10/21/16 08:17 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
The black line is steel, I just painted it black. The only rubber is that short piece connecting the pump line to the carb line. Couple inches of high pressure fuel line and fuel injection clamps that are smooth and don't tear the hose up like typical worm type clamps.
Re: 440 with CH4B conversion from Eddy 750 to Holley/Quickfuel [Re: Dcuda69] #2179981
10/21/16 10:05 PM
10/21/16 10:05 PM
Rittman Ohio
Rittman Ohio
I found these pics of line kits from GM suppliers.
Gus beer
64 Plymouth Savoy
Dana 60
Re: 440 with CH4B conversion from Eddy 750 to Holley/Quickfuel [Re: fourgearsavoy] #2179984
10/21/16 10:16 PM
10/21/16 10:16 PM
Rittman Ohio
Rittman Ohio
another
64 Plymouth Savoy
Dana 60
Re: 440 with CH4B conversion from Eddy 750 to Holley/Quickfuel [Re: fourgearsavoy] #2179986
10/21/16 10:18 PM
10/21/16 10:18 PM
Rittman Ohio
Rittman Ohio
lines from Classic Industries
64 Plymouth Savoy
Dana 60
Re: 440 with CH4B conversion from Eddy 750 to Holley/Quickfuel [Re: p d'ro] #2180469
10/22/16 07:51 PM
10/22/16 07:51 PM
MD
p d'ro Offline OP
p d'ro  Offline OP
MD
These are good. Thanks! I am using the drop base mancini with the stock dual snorkel top and it looks like it would clear. I will go on their website and try to find the lines that go from the dual feed tee to the filter and pump.
