440 with CH4B conversion from Eddy 750 to Holley/Quickfuel
#2179116
10/20/16 01:18 PM
10/20/16 01:18 PM
Posts: 1,584 MD
p d'ro
MD
Hi,
My 440 has stock pistons, comp cams XE262 magnum cam, Eddy Performer heads, CH4B manifold, and stock HP exhaust manifolds, 2.5" exhaust with crossover. I want to swap the Eddy 1411 with either a Quickfuel or Holley and keep it relatively cheap. I see there is a lower cost Quickfuel VS, then a SS and Q. I really haven't had a Holley in 20 years and am not sure which Holley or Quickfuel would be best for my street cruiser. A little tuning is fine, but out of the box performance is what I prefer. Any ideas?
I have the stock finelines fuel lines/look and want to keep metal lines if possible. Does anyone have a recommendation for off the shelf lines from stock fuel pump to carb for this application. I can't find it..
Will the Holley/quickfuel fit on the CH4B or do I need an adapter?
Thanks, Pete
Re: 440 with CH4B conversion from Eddy 750 to Holley/Quickfuel
[Re: p d'ro]
#2179205
10/20/16 03:57 PM
10/20/16 03:57 PM
Posts: 10,552 Rittman Ohio
fourgearsavoy
Rittman Ohio
Your combo sounds like it could use the 750 Quickfuel VS carb but it looks like they only offer it with a dual feed line setup. I really like Quickfuel carbs for their adjustability features and the one I have ran almost perfect when I got it. It will bolt directly to your intake with new Superformance gaskets. There are a few different styles of stock looking fuel lines for this manifold and carb combination. Just search Google images for "steel line from pump to carb 440 Mopar" I found a few images pulled from this site. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: DaveRS23]
#2179380
10/20/16 09:24 PM
10/20/16 09:24 PM
Posts: 1,584 MD
p d'ro
MD
I hadn't considered those. My crossover is blocked due to the Performer heads, so that is good. I will first get my car out and see if the new squirter and accelerator pump helped at all. Then I will check prices of the carbs and the lines.' One think I noticed is that the fuel line from the Quickfuel seems to go right over the distributor due to the angle of the inlets... I do not like that..
[Re: Dcuda69]
#2179981
10/21/16 10:05 PM
10/21/16 10:05 PM
fourgearsavoy
Rittman Ohio
I found these pics of line kits from GM suppliers. Gus
[Re: fourgearsavoy]
#2179986
10/21/16 10:18 PM
10/21/16 10:18 PM
fourgearsavoy
Rittman Ohio
lines from Classic Industries
