440-6 Center Carb Issue
#2177344
10/17/16 11:23 PM
10/17/16 11:23 PM
Posts: 2,963 Wisconsin
Stewpar
Wisconsin
So, car starts up on fast idle just fine. However, it won't kick down on its own or with throttle. I have to manually touch the plastic cam on the passenger side to get it to warm idle. Any thoughts? Thanks in advance
Admiration For Multiple Carburetor Vehicles...
Re: 440-6 Center Carb Issue
[Re: Stewpar]
#2177588
10/18/16 11:41 AM
10/18/16 11:41 AM
Posts: 18,157 Mass
DAYCLONA
Mass
So, car starts up on fast idle just fine. However, it won't kick down on its own or with throttle. I have to manually touch the plastic cam on the passenger side to get it to warm idle. Any thoughts? Thanks in advance If it needs lubing, lube it as mentioned, however there is a small tang that rides on the various steps of the plastic cam for setting high speed idle, that you adjust by bending with pliers, perhaps it needs a tweak as it my be hanging up ever so slightly
[Re: DAYCLONA]
#2177659
10/18/16 01:32 PM
10/18/16 01:32 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
So, car starts up on fast idle just fine. However, it won't kick down on its own or with throttle. I have to manually touch the plastic cam on the passenger side to get it to warm idle. Any thoughts? Thanks in advance If it needs lubing, lube it as mentioned, however there is a small tang that rides on the various steps of the plastic cam for setting high speed idle, that you adjust by bending with pliers, perhaps it needs a tweak as it my be hanging up ever so slightly Mike,now you know you use a screw driver in the slot rather than pliers !!
[Re: DAYCLONA]
#2178250
10/19/16 12:18 AM
10/19/16 12:18 AM
Stewpar
Wisconsin
So, car starts up on fast idle just fine. However, it won't kick down on its own or with throttle. I have to manually touch the plastic cam on the passenger side to get it to warm idle. Any thoughts? Thanks in advance If it needs lubing, lube it as mentioned, however there is a small tang that rides on the various steps of the plastic cam for setting high speed idle, that you adjust by bending with pliers, perhaps it needs a tweak as it my be hanging up ever so slightly Alright, this could be my issue. Should it be in contact with the cam or ? It does touch/rub on the cam....... Should I insert a screw driver in the slot and twist away from the cam?
[Re: 62maxwgn]
#2178265
10/19/16 12:30 AM
10/19/16 12:30 AM
Stewpar
Wisconsin
Bill,
I have re-pop carbs on this car. I will take a picture, hold tight....
[Re: Stewpar]
#2178271
10/19/16 12:35 AM
10/19/16 12:35 AM
Stewpar
Wisconsin
Bad light, but you should get the idea.......
