firecore 440 distributor help #2175456
10/15/16 08:50 PM
10/15/16 08:50 PM
elmira ny
hp340nos Offline OP
hp340nos  Offline OP
elmira ny
at the drags today and after doing a burnout, our firecore rb 440 distributor broke the teeth off the reluctor wheel.has only about 1000 miles street/track.it was running fine all day until this happened.everything is tight.checked all screws on the dist.we put a stock dist in to drive it home.will a reluctor wheel off a stock mopar fit the firecore?motor is very mild 400hp and shifted at 5300 to 5500rpm.
Re: firecore 440 distributor help [Re: hp340nos] #2175586
10/16/16 12:07 AM
10/16/16 12:07 AM
WA
tman Offline
tman  Offline
WA
Contact Firecore. Im sure they will get you what you need. Bummer what happened though. Is the pickup damaged from hitting the reluctor? or what hit the reluctor? Send a photo if you can.
http://www.firecore50.com/
Re: firecore 440 distributor help [Re: hp340nos] #2175673
10/16/16 02:51 AM
10/16/16 02:51 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Talk to Rick,he will do the right thing!
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: firecore 440 distributor help [Re: hemi-itis] #2175976
10/16/16 12:54 PM
10/16/16 12:54 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
Do your self a favor and throw it in the trash and order an MSD - the firecore/Summit/Jegs are junk!
Re: firecore 440 distributor help [Re: hp340nos] #2176055
10/16/16 02:40 PM
10/16/16 02:40 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
How do you break teeth off a reluctor wheel ??????
Re: firecore 440 distributor help [Re: Stanton] #2176412
10/16/16 09:55 PM
10/16/16 09:55 PM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
I have had 2 of the Firecore distributors go bad on me and will never have another one. The weights broke loose on both of them causing all kinds of issues that could have led to some major damage. Some people may get by with these on a very seldom used street car but not at all in any race application. twocents
Re: firecore 440 distributor help [Re: hp340nos] #2176453
10/16/16 10:35 PM
10/16/16 10:35 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Very disturbing.
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: firecore 440 distributor help [Re: DoubleD] #2176542
10/16/16 11:42 PM
10/16/16 11:42 PM
mn.
taxidermy man Offline
mn.
I'm starting to believe you are correct,I'm having some Firecore issues of my own.
Re: firecore 440 distributor help [Re: taxidermy man] #2176561
10/17/16 12:08 AM
10/17/16 12:08 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
I was on the fence about buying a Firecore distributor for my 511, but all the issues I have seen on here and other sites makes me look all the harder at the Pertronix. I had issues with my MSD billet as well til I added the crank trigger. I can say this thou, Firecore wires are nice.
Re: firecore 440 distributor help [Re: taxidermy man] #2176709
10/17/16 10:10 AM
10/17/16 10:10 AM
Big Western Pencilveinya
U
Uncle Barry Offline
Uncle Barry  Offline
U
Can I ask what kind of issues are you having with yours? Just wanting a heads up. Mine seems to be fine. But its just a street car and doesn't get driven much.
Re: firecore 440 distributor help [Re: DoubleD] #2176786
10/17/16 12:29 PM
10/17/16 12:29 PM
fresno ca
mikeysmopars Offline
fresno ca
iagree
Founder and CEO of the Central Valley Mopar Drag Pack
Re: firecore 440 distributor help [Re: Uncle Barry] #2176890
10/17/16 02:13 PM
10/17/16 02:13 PM
mn.
mn.
Barry, been fighting a no spark issue for quite some time, I have 12 volts to the coil in the run position and about 10 cranking, new coil, new motherboard, good ground, every thing sees to check out, just doesn't work. I have it in the back of my head that it's something I'm doing wrong but I'm at a loss.
Re: firecore 440 distributor help [Re: taxidermy man] #2176897
10/17/16 02:19 PM
10/17/16 02:19 PM
MD-USA
Dodgeguy101 Offline
Dodgeguy101  Offline
MD-USA
Just throwing this out there, but have you tried reversing the wires going to the distributor? I thought I read it will still start if they are reversed, but will run like crap. Might not be your problem, but just a suggestion.
Re: firecore 440 distributor help [Re: hp340nos] #2176916
10/17/16 02:37 PM
10/17/16 02:37 PM
mn.
mn.
Dodgeguy, are you saying to reverse the + - wires on the coil coming from the distributor? Thanks, didn't mean to hi jack this thread.
Re: firecore 440 distributor help [Re: taxidermy man] #2177036
10/17/16 04:51 PM
10/17/16 04:51 PM
MD-USA
Dodgeguy101 Offline
Dodgeguy101  Offline
MD-USA
Yes, only reason I say that, and not going to start a bashing here, but I had a firecore distributor, and i recently got a MSD distributor and the wires from each were different colors with the strip. I have a MSD 7al2 box I bought in the 80's at some point never used it until a few years ago. The wire color was different and had read allot of threads, but I guess I got lucky when I wired mine up. Was just a suggestion to try, not saying that is your problem, but I would try it to rule it out as a problem.
Re: firecore 440 distributor help [Re: Dodgeguy101] #2177061
10/17/16 05:28 PM
10/17/16 05:28 PM
Rittman Ohio
fourgearsavoy Online tonguue
fourgearsavoy  Online Tonguue
Rittman Ohio
I still have the first Firecore50 distributor that Rick sold and it's still working great since the first day I got it.
I have about 30 passes on it and a few thousand street miles with zero issues.
I did have to switch the pickup polarity before I fired it up.
Gus beer
64 Plymouth Savoy
Dana 60
Re: firecore 440 distributor help [Re: fourgearsavoy] #2177063
10/17/16 05:31 PM
10/17/16 05:31 PM
dogdays Offline
dogdays  Offline
The wire reversal that makes a difference is between the pickup coil and the module.
Gotta go,
R.
Re: firecore 440 distributor help [Re: dogdays] #2177288
10/17/16 10:23 PM
10/17/16 10:23 PM
fullmetaljacket Offline
Firecore 50 distributor and wires here as well with no issues.
Hope craftmanship has not been compromised since. I'm sure rick will reverse all, the issues and come correct. Great guy to work with and purchase from.
Re: firecore 440 distributor help [Re: fullmetaljacket] #2177535
10/18/16 10:13 AM
10/18/16 10:13 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
mine works great,ive only been to the track a few times but i put about 4,000 street miles on it with ALOT of 6,000 rpm shifts. drive
Re: firecore 440 distributor help [Re: hp340nos] #2178020
10/18/16 07:31 PM
10/18/16 07:31 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Still no word from Rick?
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
