Re: '67 Belvedere Steering Column Rebuild
[Re: gtx6970]
#2176765
10/17/16 11:58 AM
10/17/16 11:58 AM
Posts: 9,066 Eugene, Oregon
minivan
Eugene, Oregon
Like said ,,, the lower bearing on a 67 is a weird animal and can be a little complicated to a novice. Its a one year only deal
Indeed, an unobtainable part... Had to have a machine shop manufacture the plastic piece, that holds the metal retainer ( where the ball bearings fit into) . Purchased a package of new ball bearings also at a bearing supply house...
[Re: gtx6970]
#2177137
10/17/16 07:15 PM
10/17/16 07:15 PM
Posts: 207 People's Republic of Mass.
Belvedere2
Only thing in there will cause in kind of dead spot is looseness in the lower coupler. Or worst case ( it would have to be pretty bad ) is wear between the 2 sections of the main shaft itself.( never seen that though)
I can do it if your not comfortable doing so . I have a 68 Column on the bench now actually. Thank you. You can PM me what I'd need to do to get the part/column to you. Cost etc.
[Re: Belvedere2]
#2180277
10/22/16 12:58 PM
10/22/16 12:58 PM
Posts: 238 Okla
dpatt67
Okla
SMSmopar.com rebuilds columns
66 Coronet 67 Satellite 15 Ram 3500 12 Challenger R/T
[Re: minivan]
#2184959
10/28/16 11:06 PM
10/28/16 11:06 PM
Posts: 4,275 Morrow, OH
markz528
Morrow, OH
Indeed, an unobtainable part... Had to have a machine shop manufacture the plastic piece, that holds the metal retainer ( where the ball bearings fit into) . Purchased a package of new ball bearings also at a bearing supply house... There is a fellow making the lower bearing kit for a 67. I bought one in case I ever need it for my cars.
[Re: markz528]
#2184976
10/28/16 11:22 PM
10/28/16 11:22 PM
minivan
Eugene, Oregon
Indeed, an unobtainable part... Had to have a machine shop manufacture the plastic piece, that holds the metal retainer ( where the ball bearings fit into) . Purchased a package of new ball bearings also at a bearing supply house... There is a fellow making the lower bearing kit for a 67. I bought one in case I ever need it for my cars. Good to know.. Do you have a website or name??
[Re: minivan]
#2184986
10/28/16 11:34 PM
10/28/16 11:34 PM
markz528
Morrow, OH
Indeed, an unobtainable part... Had to have a machine shop manufacture the plastic piece, that holds the metal retainer ( where the ball bearings fit into) . Purchased a package of new ball bearings also at a bearing supply house... There is a fellow making the lower bearing kit for a 67. I bought one in case I ever need it for my cars. Good to know.. Do you have a website or name?? http://dynamicrenovation.net/viewitem.php?productid=90
