Old ignition switch #2173639
10/13/16 02:36 PM
10/13/16 02:36 PM
mississippi
bentwheel43 Offline OP
mississippi
I guess my ignition switch went out, when its on crank it starts and when I let the key go it kills. Its on a 1966 Satillite where would I get a new one?
Section 8 Racing We are nuts about racing.
Re: Old ignition switch [Re: bentwheel43] #2173647
10/13/16 02:45 PM
10/13/16 02:45 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Sounds like a ballast resister, have to tried that first ?
Re: Old ignition switch [Re: OzHemi] #2173655
10/13/16 02:53 PM
10/13/16 02:53 PM
iagree scope
You can verify two things by using a volt ohm meter on the ballast resitor, one is the resitor and the other is the ignition switch and wiring by having someone else put the tranny in any gear other than nuetral or park and turn the key to the start position while you put the volt meter leads on both ends of the ballast resitor to see if you have voltage or not. You should see voltage on one end but not both scope If you have that then have the other person release the ignition switch to the run position and see if you have voltage on both ends of the resitor, you shuold have 12+ volts on one end and less volts on the othor end going to the coil + side in the run position scope
Let us konw what you find please, that may help others on here later luckwork
Re: Old ignition switch [Re: bentwheel43] #2173656
10/13/16 02:54 PM
10/13/16 02:54 PM
Northern MN
1E2C Offline
1E2C  Offline
Northern MN
Yep, start with the cheaper and easier fix. And if you have a multimeter you can check it first.
Re: Old ignition switch [Re: bentwheel43] #2173682
10/13/16 03:24 PM
10/13/16 03:24 PM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
Bad connection at either bulkhead or ignition switch to under dash wiring harness.
Re: Old ignition switch [Re: Sxrxrnr] #2173708
10/13/16 03:55 PM
10/13/16 03:55 PM
mississippi
mississippi
it had a MSD-6al with a accel super coil no points. When I took the resistor off it had rust on the ground, that just may have been the ground wire someone put under the resistor.
Re: Old ignition switch [Re: bentwheel43] #2173729
10/13/16 04:17 PM
10/13/16 04:17 PM
mississippi
mississippi
Well when I cleaned the rust off and put the resistor back on it cranked right up, good thing I didn't go buy a new switch it looked like it would be hard to change with my big hand. Thanks a lot fellas.
Re: Old ignition switch [Re: bentwheel43] #2173983
10/13/16 08:28 PM
10/13/16 08:28 PM
the ballast ain't grounded so it sounds like you just had a loose connection, one of the ones that you were dealing with in working on this issue. All good now & if it acts up again just check your connections in the blue wire (ign1 "run") circuit
Re: Old ignition switch [Re: bentwheel43] #2174120
10/13/16 10:47 PM
10/13/16 10:47 PM
Corrosion is a good insulator and causes many problems with electrical cicuits in cars and every thing else using electricity including airplanes shruggy
It pays to trouble shoot the problem first before replacing partsup
