318 non a/c belt set up? #2172884
10/12/16 01:44 PM
10/12/16 01:44 PM
Albuquerque, new mexico
moparvinson Offline OP
does anyone have a picture of the belt set up on a small block with no a/c? my son wants to remove the non working a/c on his 1974 charger but the alt. uses the a/c bracket and the water pump pulley is only a single groove. Thanks for any help.
Re: 318 non a/c belt set up? [Re: moparvinson] #2172892
10/12/16 01:59 PM
10/12/16 01:59 PM
the water pump/crank pullies as you know just need to line up & 440source & speedway have shims (speedways are chebbies but they fit (the WP ones only from them I have used) so you are needing a pic of a non AC alt bracket setup?
Re: 318 non a/c belt set up? [Re: RapidRobert] #2172899
10/12/16 02:05 PM
10/12/16 02:05 PM
yes, right now he has 2 belts that go from crank to a/c to alt, and one goes from crank to p.s. pump to water pump.
Re: 318 non a/c belt set up? [Re: moparvinson] #2172919
10/12/16 02:32 PM
10/12/16 02:32 PM
likely you can keep the 4 groove crank pulley (looks unsightly tho) & how is the WP pulley looking as far as lining up with one of the crank grooves? (& using grooves that will line up with the alt & you can use either one of the alt grooves & the alt can be easily spaced forward or backward (to some extent). it might be awhile till I can get over to the shop & take a pic. a piece of tubing or a laser pointer works well for dead on pulley alignment for racing but for a low po app eyeballing is adequate.
Re: 318 non a/c belt set up? [Re: moparvinson] #2172931
10/12/16 02:42 PM
10/12/16 02:42 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Bouchillon has the proper brackets and pulleys.
Re: 318 non a/c belt set up? [Re: RapidRobert] #2172955
10/12/16 03:25 PM
10/12/16 03:25 PM
so the power steering pump will run from the crank pulley only and the alt. will go from crank to water pump to alt. since he only has a single groove water pump pulley?
Re: 318 non a/c belt set up? [Re: moparvinson] #2172978
10/12/16 03:56 PM
10/12/16 03:56 PM
Correct
Re: 318 non a/c belt set up? [Re: RapidRobert] #2173389
10/13/16 05:18 AM
10/13/16 05:18 AM
I'll see if I can get you a pic tomorrow
Re: 318 non a/c belt set up? [Re: moparvinson] #2178110
10/18/16 09:47 PM
10/18/16 09:47 PM
North of the Motor City
DartGTDan Offline
DartGTDan  Offline
Check out here:
http://www.cardomain.com/ride/2615706/1971-dodge-dart/
This is what I did to my '71 Dart GT.
