Re: 318 non a/c belt set up?
[Re: moparvinson]
#2172892
10/12/16 01:59 PM
10/12/16 01:59 PM
RapidRobert
the water pump/crank pullies as you know just need to line up & 440source & speedway have shims (speedways are chebbies but they fit (the WP ones only from them I have used) so you are needing a pic of a non AC alt bracket setup?
[Re: moparvinson]
#2172919
10/12/16 02:32 PM
10/12/16 02:32 PM
RapidRobert
likely you can keep the 4 groove crank pulley (looks unsightly tho) & how is the WP pulley looking as far as lining up with one of the crank grooves? (& using grooves that will line up with the alt & you can use either one of the alt grooves & the alt can be easily spaced forward or backward (to some extent). it might be awhile till I can get over to the shop & take a pic. a piece of tubing or a laser pointer works well for dead on pulley alignment for racing but for a low po app eyeballing is adequate.
[Re: moparvinson]
#2172978
10/12/16 03:56 PM
10/12/16 03:56 PM
RapidRobert
so the power steering pump will run from the crank pulley only and the alt. will go from crank to water pump to alt. since he only has a single groove water pump pulley? Correct
[Re: RapidRobert]
#2173389
10/13/16 05:18 AM
10/13/16 05:18 AM
RapidRobert
I'll see if I can get you a pic tomorrow
