Gear whine under decel #2172695
10/12/16 03:24 AM
10/12/16 03:24 AM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
Must have hurt the ole 8.75 last time at the track. Major whine under decel. Very very loud. Almost sounds like a siren, its so dang loud.
Pinion bearing, lost some teeth? What are the usual culprits for decel whine?
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Gear whine under decel [Re: Von] #2172703
10/12/16 06:27 AM
10/12/16 06:27 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
Probably pinion bearing.
Don't wait until it locks it... that can be a scary ride...
Re: Gear whine under decel [Re: Von] #2172776
10/12/16 11:12 AM
10/12/16 11:12 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
If you're in luck the pinion nut has come loose, if not, rebuild time
beer
Re: Gear whine under decel [Re: Von] #2172787
10/12/16 11:30 AM
10/12/16 11:30 AM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
Center has maybe 500 miles since rebuild. Bet its a bearing...
Re: Gear whine under decel [Re: Von] #2172819
10/12/16 12:12 PM
10/12/16 12:12 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Could have been low on fluid and upon acceleration the pinion bearing was starved of lube. Pull the pig and check it out.
Abe Lincoln
Re: Gear whine under decel [Re: dart4forte] #2172852
10/12/16 01:01 PM
10/12/16 01:01 PM
As said pull it out ASAP
Re: Gear whine under decel [Re: RapidRobert] #2172863
10/12/16 01:20 PM
10/12/16 01:20 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Why not check the pinion nut first ??? if it is loose, Loctite and retorque it, see if noise goes away. I have seen many examples over the years and had it happen to me once. it makes helluva whine on deccel as the pinion is pulled back into the differential housing, See attached pic
If it's not loose then pull it whistling twocents
Re: Gear whine under decel [Re: Von] #2172916
10/12/16 02:31 PM
10/12/16 02:31 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Sounds like the nut is loose, the only way it gets that loud, I have heard it, sounds like a locomotive in the trunk! It is not a bad bearing making that noise.
Re: Gear whine under decel [Re: NANKET] #2172929
10/12/16 02:42 PM
10/12/16 02:42 PM
that'd sure be a nice break for you if the nut is loose & tightening it takes care of it
Re: Gear whine under decel [Re: Von] #2173010
10/12/16 04:43 PM
10/12/16 04:43 PM
crlush Offline
crlush  Offline
If it has a crush sleeve 489 case then that could be it, or like everyone else said pinion bearing or loose nut.
