Gear whine under decel
#2172695
10/12/16 03:24 AM
10/12/16 03:24 AM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
Must have hurt the ole 8.75 last time at the track. Major whine under decel. Very very loud. Almost sounds like a siren, its so dang loud.
Pinion bearing, lost some teeth? What are the usual culprits for decel whine?
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Gear whine under decel
[Re: Von]
#2172787
10/12/16 11:30 AM
10/12/16 11:30 AM
Von
NE Oklahoma
Center has maybe 500 miles since rebuild. Bet its a bearing...
[Re: Von]
#2172819
10/12/16 12:12 PM
10/12/16 12:12 PM
Posts: 16,150 Mesa, Arizona
dart4forte
Mesa, Arizona
Center has maybe 500 miles since rebuild. Bet its a bearing... Could have been low on fluid and upon acceleration the pinion bearing was starved of lube. Pull the pig and check it out.
Abe Lincoln
[Re: NANKET]
#2172929
10/12/16 02:42 PM
10/12/16 02:42 PM
RapidRobert
that'd sure be a nice break for you if the nut is loose & tightening it takes care of it
