Overheating problem solved!! #217246
02/07/09 09:49 PM
02/07/09 09:49 PM
Spartanburg SC
MoparDan Offline OP
MoparDan  Offline OP
Spartanburg SC
I have a 71 RR, 340/416, new everything, including 4 core radiator, shroud and Napa a/c water pump. The car would run great, but after 10 min of driving, or at any stop/idling would begin to overheat...steady right over to H! Then I'd turn it off to cool, the motor would sorta sound like a coffee maker..puff/snort/pfff...upper hose would be at a fast boil, and water would be coming out the overflow, but no where else. I tried new carb; different temp thermostats; timed it up, down and sideways; checked this, checked that, I was certain it was a clogged block/ heads...Then I called Ken Hensley at Hensley Performance. Ken said clogged blocks are down on his list of newly machined motors which overheat. but there's many poor "new" parts-store water pumps out there, and AutoZone type thermostats were not the best choice for well cammed stroker motors....Ken suggested a Milodon high-volume waterpump, and Milodon 160 thermostat, and 12-15 degrees advance inital timing, to let my quick-fuel 770 VS know to give adequate gas,
Problem SOLVED!!! I drove it over one hour, about60 miles with spotlights & a Micky D's drivethough. The motor never when above 175 degrees (and today it was about 70) Plus the motor was quite at shut down, makes me think the motors cooling system was not "sealed" or air-pocket...or blades on the old "new" water pump were slipping.
Anyway, though I'd share this as overheating is very common in our old mopars. I can't thank Ken Hensley enough, my car has been finished for almost two years...except I couldn't drive it for more than about 10-15 minutes. I am so psyched! Tomorrow is supposted to be beautiful here in SC, and the wife and I are going for a CRUSE!
Re: Overheating problem solved!! [Re: MoparDan] #217247
02/07/09 10:00 PM
02/07/09 10:00 PM
you sound happy. Glad ya got it.
Re: Overheating problem solved!! [Re: RapidRobert] #217248
02/07/09 10:06 PM
02/07/09 10:06 PM
Badham Co.
Y
Y3 70 BEE Offline
Y3 70 BEE  Offline
Y
Badham Co.
Nothing better than a cheap looking RR.
Re: Overheating problem solved!! [Re: Y3 70 BEE] #217249
02/07/09 10:13 PM
02/07/09 10:13 PM
Spartanburg SC
MoparDan Offline OP
MoparDan  Offline OP
Spartanburg SC
Hey it's not cheap! ..this is the ultimate sleeper look...PLUS hub caps and whitewalls were how it came from the factory! though, I'm budgeting for BFG's 245/60's front, 255/60's rear, on a set of ET Kelstars I have.
Re: Overheating problem solved!! [Re: MoparDan] #217250
02/07/09 10:15 PM
02/07/09 10:15 PM
None
71rm23 Offline
71rm23  Offline
None
Looks cool
Re: Overheating problem solved!! [Re: 71rm23] #217251
02/07/09 10:24 PM
02/07/09 10:24 PM
Badham Co.
Y
Y3 70 BEE Offline
Y3 70 BEE  Offline
Y
Badham Co.
It looks great get some 70s style mud flaps to keep the rubber off the quarters.
Re: Overheating problem solved!! [Re: Y3 70 BEE] #217252
02/08/09 04:49 AM
02/08/09 04:49 AM
Woodbridge,CA
NAS Backyard Offline
Woodbridge,CA
Thats great to hear. I'm having a problem on my 440 getting hot in traffic only. I have an Edelbrock waterpump, Milodon thermostat, pusher fan. I do need a good tune up after 10K miles.
1970 Challenger Ragtop 426 4 speed 1961 Olds 88 2 dr Sedan 394 4 speed GVOD 1968 Pontiac Firebird 428 4 speed 2000 Ford F-150 2002 HD Roadking 1961 Licence Plate collection 1995 Buick Roadmaster www.nogreenautolaws.com
Re: Overheating problem solved!! [Re: MoparDan] #217253
02/08/09 04:56 AM
02/08/09 04:56 AM
North Carolina
jt1 Offline
jt1  Offline
North Carolina
Glad you found the problem. It's going to be gorgeous today, get her out and cruise that baby around a while!!!!
John
Re: Overheating problem solved!! [Re: NAS Backyard] #217254
02/08/09 07:33 AM
02/08/09 07:33 AM
My the fan is inadequate for your app
Re: Overheating problem solved!! [Re: RapidRobert] #217255
02/08/09 08:48 PM
02/08/09 08:48 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
Glad to hear you got it fixed. You have that sleeper look down!
