Repairing 1970 Charger Ignition switch connector #2168895
10/06/16 11:44 AM
10/06/16 11:44 AM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
A friend had his ignition switch plug burn out. This is the plug that connects the ignition switch to the interior harness.
The Main Red power wire burnt at the connector and the previous owner used a yellow butt splice. Clearly this cant stay. I wanted to splice it together properly with solder, but before I do I'd like to see if the harness side of the plug is available for purchase. Also, what are the crimp on pins for this connection called? I've never used that style before.
I'm looking for the opposite side of that white connector.
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: Repairing 1970 Charger Ignition switch connector [Re: AlexP] #2168914
10/06/16 12:19 PM
10/06/16 12:19 PM
www.classicindustries.com might have something. if you make a small purchase from them then 2 weeks later their pricey Mopar specific catalogue will arrive unannounced in your mailbox & it is a must have reference item with comprehensive selections in many categories & pics.
Re: Repairing 1970 Charger Ignition switch connector [Re: AlexP] #2169015
10/06/16 03:34 PM
10/06/16 03:34 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
send Jim at JS Restorations an e-mail. He's an absolute whiz at these electrical parts. his work is awesome! here's a link to his under construction website that has his email. there is also an extensive thread in the Hot Deals and Products forum.
Re: Repairing 1970 Charger Ignition switch connector [Re: AlexP] #2169018
10/06/16 03:39 PM
10/06/16 03:39 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
I believe that's a Molex connector, try here to see if you can match it:
http://www.mouser.com/molex/Connectors/Automotive-Connectors/_/N-1ehb5?P=1z0zlew
Re: Repairing 1970 Charger Ignition switch connector [Re: AlexP] #2169046
10/06/16 04:28 PM
10/06/16 04:28 PM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
Only source that I have found for this plastic connector, was to buy the complete dashboard wiring harness from Year 1 supplied to them by M&H who builds it. I did purchase the wiring harness as I wanted it anyhow.
M&H finds them somewhere. Perhaps they will share their source.
http://www.wiringharness.com/chrysler.htm
All the required molex pins are available in differing sizes.
Re: Repairing 1970 Charger Ignition switch connector [Re: Sxrxrnr] #2169367
10/07/16 12:04 AM
10/07/16 12:04 AM
IN
ahy Offline
ahy  Offline
IN
That is kinda a weak spot in the OE setup. Much like the bulkhead connector. A soldered and correctly insulated connection sounds like a good idea to me. It would also not hurt to make sure any added loads like more powerful stereo ect. do not draw power through that circuit. A separate circuit with relay powered directly from the fender relay or battery is better. Key on power from the OE setup can trigger the relay but not support the main load.
Re: Repairing 1970 Charger Ignition switch connector [Re: ahy] #2169464
10/07/16 05:36 AM
10/07/16 05:36 AM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
Agreed. There are many poor engine performance, failure to start, and other mysterious electrical conditions that originate at this connector. A very often overlooked problem area.
Re: Repairing 1970 Charger Ignition switch connector [Re: AlexP] #2169539
10/07/16 11:44 AM
10/07/16 11:44 AM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
I just soldered ring terminals on the high-load wires and bolted
them together, easy, effective and permanent.
Joe
