A friend had his ignition switch plug burn out. This is the plug that connects the ignition switch to the interior harness.
The Main Red power wire burnt at the connector and the previous owner used a yellow butt splice. Clearly this cant stay. I wanted to splice it together properly with solder, but before I do I'd like to see if the harness side of the plug is available for purchase. Also, what are the crimp on pins for this connection called? I've never used that style before.
I'm looking for the opposite side of that white connector.
