Are 70- 74 Challenger bumper brackets the same?? #2167294
10/03/16 08:59 PM
10/03/16 08:59 PM
Fairfield, Ohio
holtzdog55 Offline OP
Fairfield, Ohio
wanting to buy the 70-71 bumpers on ebay that dont have the jack slot....was wondering if they will fit a 72 challenger.....
Thanks in advance.....
Finally Done....BEERS!!!
Re: Are 70- 74 Challenger bumper brackets the same?? [Re: holtzdog55] #2167299
10/03/16 09:03 PM
10/03/16 09:03 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
My 73 has the stock front bumper brackets slid back and 72 rear bumper brackets. The bumpers are replaced with those which have no slots.
Doug
Re: Are 70- 74 Challenger bumper brackets the same?? [Re: holtzdog55] #2167303
10/03/16 09:06 PM
10/03/16 09:06 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
I don't think they are all the same. The bumpers stuck out farther on the 72-74 with a filler strip in between. I believe the 74 had a shock absorber (5mph)situation.
Re: Are 70- 74 Challenger bumper brackets the same?? [Re: dvw] #2167311
10/03/16 09:15 PM
10/03/16 09:15 PM
Fairfield, Ohio
Fairfield, Ohio
that helps alittle, still unsure.....wont have to buy for awhile yet....the guy on ebay sas the 7-=71 bumpers are the same as the 71-72 bumpers he sells except the 70-71 doesnt have the jack slot.........
Re: Are 70- 74 Challenger bumper brackets the same?? [Re: holtzdog55] #2167328
10/03/16 09:51 PM
10/03/16 09:51 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
The BUMPERS are the same except for maybe the bolt holes for the bumperettes in 73-74. The BRACKETS, I don't believe are the same. Mines a 72 and has the stock rear bumper on custom brackets so that it fits close to the car. This is a 74 with the bumperettes. Picture taken in 1979 I think. [img]https://scontent-dft4-1.xx.fbcdn.net/v/t...amp;oe=58791994[/img] You can see the argent colored filler pieces front and rear.
This my 72 with the stock bumper moved close to the car. [img]https://scontent-dft4-1.xx.fbcdn.net/v/t...amp;oe=586B631E[/img]
Re: Are 70- 74 Challenger bumper brackets the same?? [Re: holtzdog55] #2167563
10/04/16 09:30 AM
10/04/16 09:30 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
The 72 rear bracket pulls the bumper in like the 70-71. Mine still has the original 73 front brackets that were on the car when it was stock. The rear bumperets fit as well. Everything fits. I also put a 70 grille in it. But that takes a bit of fab work.
Doug
Re: Are 70- 74 Challenger bumper brackets the same?? [Re: holtzdog55] #2167617
10/04/16 11:18 AM
10/04/16 11:18 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
The 70-72 bumper brackets are the same. 70-72 bumpers have the same profile but in late 71, they added the jack slots.
73 rear bumper brackets are a one year only deal. They look like the Cuda style brackets. They are a stamped metal part...not just bar stock.
74 rear bumper brackets are a one year only deal. They went back to a bar stock bracket.
I believe(not100%)that 73 and 74 front brackets are the same.
73 and 74 bumpers have a different profile then 70-72. Try mounting a 73-74 bumper guard on a 70-72 bumper and you will see the difference. 73-74 had thick/heavy metal reinforcement plates behind the bumpers.(front and rear)
I don't believe any E-body ever came with a shock absorber style mount.
Re: Are 70- 74 Challenger bumper brackets the same?? [Re: burdar] #2167621
10/04/16 11:39 AM
10/04/16 11:39 AM
Fairfield, Ohio
Fairfield, Ohio
sounds like they will fit OK then.....
Thanks to all for the responses.....
