RV2 compressor shaft seal maintenance #2166347
10/02/16 10:42 AM
10/02/16 10:42 AM
Houston, TX
sbklf Offline OP
sbklf  Offline OP
Houston, TX
I read that the AC should be cycled often to prevent shaft seal leakage on these RV2 compressors. If that is true, can rotating the compressor several revolutions by hand be effective?
Re: RV2 compressor shaft seal maintenance [Re: sbklf] #2166352
10/02/16 10:53 AM
10/02/16 10:53 AM
Ringtown, Pa.
Dartsport540 Offline
Ringtown, Pa.
Just turn the defrost on now and then. The a/c should run on defrost. Or , just turn the a/c on for a few minutes.
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
Re: RV2 compressor shaft seal maintenance [Re: Dartsport540] #2166405
10/02/16 01:11 PM
10/02/16 01:11 PM
Houston, TX
sbklf Offline OP
sbklf  Offline OP
Houston, TX
? Point is, I am trying to do this without starting the car.
Re: RV2 compressor shaft seal maintenance [Re: sbklf] #2166407
10/02/16 01:21 PM
10/02/16 01:21 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
Running
