Re: RV2 compressor shaft seal maintenance
[Re: sbklf]
#2166352
10/02/16 10:53 AM
10/02/16 10:53 AM
Posts: 1,647 Ringtown, Pa.
Dartsport540
Ringtown, Pa.
Just turn the defrost on now and then. The a/c should run on defrost. Or , just turn the a/c on for a few minutes.
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
[Re: Dartsport540]
#2166405
10/02/16 01:11 PM
10/02/16 01:11 PM
Posts: 15 Houston, TX
sbklf
Houston, TX
Just turn the defrost on now and then. The a/c should run on defrost. Or , just turn the a/c on for a few minutes. ? Point is, I am trying to do this without starting the car.
[Re: sbklf]
#2166407
10/02/16 01:21 PM
10/02/16 01:21 PM
Posts: 6,224 JERSEY
RJS
JERSEY
Just turn the defrost on now and then. The a/c should run on defrost. Or , just turn the a/c on for a few minutes. ? Point is, I am trying to do this without starting the car. Running
