Page 9 of 85 1 2 7 8 9 10 11 84 85
Re: paint job on a budget!? [Re: MNobody] #21650
02/02/06 11:59 PM
02/02/06 11:59 PM
Rancho Cordova, CA
Exit1965 Online tonguue
Exit1965  Online Tonguue
Rancho Cordova, CA
i'm getting too much orange peel too i've tried it thinner, thicker, warmer, colder, can't seem to get it right
are you using rustoleum enamel?
I think my orange peel batch wasn't thin enough, but hopefully it will come out with the wetsanding.
Re: paint job on a budget!? [Re: The Shadow] #21651
02/03/06 12:06 AM
02/03/06 12:06 AM
Great Lakes State
O
ONEBADBIRD Offline
ONEBADBIRD  Offline
O
Great Lakes State
What kind of Rustoleum paint did you guys use? I think this idea is great and I'm going to try it. The thing is I went out to buy the paint and almost bought the waterbased Rustoleum (Painters Touch) which is not oil based, but says you can use it on metal?? what caught my eye was that it said thin with water so I stayed away from that and got the other label that says (stops rust)and thins with mineral spirits. Just a thought? It almost screwed me up!!!! Jay.
Fair winds, and following seas! Red sky at night sailor's delight, red sky in morning sailor take warning! Weather from the West is always best! Weather from the East is not fit for man nor beast!
Re: paint job on a budget!? [Re: ONEBADBIRD] #21652
02/03/06 12:19 AM
02/03/06 12:19 AM
Asheboro NC
mopowertim Offline
super gas
mopowertim  Offline
super gas
Asheboro NC
We did a old catering van with rustoleum white a while back after seeing the guys on Monster Garage do it to an old Milk Truck- we used pretty much the mix ratio talked about here, scuffed it with Scotch Brite and rolled it on!! Every bit as good as a Maaco cheapie job, for about 1/8th the price!! !! The 66 Valiant wagon is getting ready to get a few coats of Bright Red the same way real soon!!
If you can't outrun it-Outlaw it! The King
Re: paint job on a budget!? [Re: mopowertim] #21653
02/03/06 12:29 AM
02/03/06 12:29 AM
MNobody Offline
MNobody  Offline
i'm using rustoleum oil based
Re: paint job on a budget!? [Re: MNobody] #21654
02/03/06 12:39 AM
02/03/06 12:39 AM
waterford
Scatpak Offline
super street
Scatpak  Offline
super street
waterford
This is a great post, keep the results coming. Can't wait to see the finished product.
Re: paint job on a budget!? [Re: MNobody] #21655
02/03/06 12:49 AM
02/03/06 12:49 AM
Great Lakes State
O
ONEBADBIRD Offline
ONEBADBIRD  Offline
O
Great Lakes State
Oh O.K. RCRC I almost did not read the fine print and bought the wrong paint. I'm going to give this a try as soon as possible soon as I prep some of the body. I'm going to go over the old paint on most of my car just rough it up a bit. I'm assuming I can just use some steelwool or scotchbrite pads? Another question is if I decide to do the black hoodstripes in gloss as well as the rest of the car can you wetsand with two colors on the hood or would that be a problem?
Thanks for any responces: Jay
Re: paint job on a budget!? [Re: mopowertim] #21656
02/03/06 10:42 AM
02/03/06 10:42 AM
Rancho Cordova, CA
Rancho Cordova, CA
How did you apply it? Was it the same as described here (2 coats, wetsand, 2 coats, wetsand, 2 more coats, wetsand then polish)?
Got any pics?
Re: paint job on a budget!? [Re: Exit1965] #21657
02/03/06 11:17 AM
02/03/06 11:17 AM
Az
69hemibeep Offline
69hemibeep  Offline
Az
About three years ago I shot my jeep with white Rustoleum.Just mixed it with mineral spirits to the same thickness as an enamel, then set my compressor to 70 and shot.Looks good !
1969 Hemi Roadrunner 2nd owner
Re: paint job on a budget!? [Re: 69hemibeep] #21658
02/03/06 06:12 PM
02/03/06 06:12 PM
MNobody Offline
MNobody  Offline
i finaly got a good coat of paint on one side of the hood i'm painting, thin that paint out boys just like water then go over it after about 5 min with the roller again. i'm buying a spray gun because if the paint is that thin it would probably be a pain to do the sides of a car and if you get one coat with orange peel and don't sand it back smooth you just keep getting the peel look.
Re: paint job on a budget!? [Re: MNobody] #21659
02/03/06 07:13 PM
02/03/06 07:13 PM
Rancho Cordova, CA
Rancho Cordova, CA
If you're going to spray, why not jump up to a cheap single stage. I figured the main advantage to this was you could apply it with a roller, no overspray, etc.
Re: paint job on a budget!? [Re: Exit1965] #21660
02/03/06 07:38 PM
02/03/06 07:38 PM
MNobody Offline
MNobody  Offline
guess it depends on the price of the materials for the single stage paint and how durable the rustoleum is, as soon as this coat dries i'm going to see how chip and scratch resistant it is.
Re: paint job on a budget!? [Re: MNobody] #21661
02/04/06 11:33 AM
02/04/06 11:33 AM
Anonymous OP
Anonymous OP
Re: paint job on a budget!? #21662
02/04/06 12:42 PM
02/04/06 12:42 PM
Rancho Cordova, CA
Rancho Cordova, CA
I have my 5th coat done and it looks OK, not as much orange peel as after I first painted it but still too much for my eye, so I went at it with 600 grit and water again.
Now it's smoother, but took a lot of paint off so you can see through it, so it'll be 2 more coats later today, wetsand, then 2 more final coats.
Re: paint job on a budget!? [Re: Exit1965] #21663
02/04/06 01:53 PM
02/04/06 01:53 PM
Great Lakes State
O
ONEBADBIRD Offline
ONEBADBIRD  Offline
O
Great Lakes State
Its very interesting to see what results you guys are getting keep the updates coming.
Re: paint job on a budget!? [Re: ONEBADBIRD] #21664
02/06/06 02:06 AM
02/06/06 02:06 AM
Anonymous OP
Anonymous OP
Man do I love this thread. I am new to this forum but found out about it through hybridz.org a wonderful site dedicated to customizing and hot rodding Datsun Z cars as well as other misc topics. Anyhow I am curious how this could be used with satin black paint. Could you wetsand between the coats until you got to the last one and the last one would self level enough for a good satin finish. Obviously you can't wetsand a satin paint and then buff?
Re: paint job on a budget!? [Re: Exit1965] #21665
02/06/06 02:20 AM
02/06/06 02:20 AM
Richmond, Tx. (Houston)
GTSDave Offline
GTSDave  Offline
600 Grit is way to rough on a top coat. You should be using at least 1000 between coats. Final with 2000.
I am not sure if you are using straight water or not, but I always use just a little dawn in my bucket and spray bottle when wet sanding. Of course I have never used this type of paint. I will give it a try one of these days.
-Dave
PLEASE Pray for our brothers and sisters in harms way.
If you are the owner of a GTS us at the GTS Registry www.gtsregistry.com
Re: paint job on a budget!? [Re: GTSDave] #21666
02/06/06 10:25 AM
02/06/06 10:25 AM
Rancho Cordova, CA
Rancho Cordova, CA
-Dave
I used the 600 to get (orange peel) material off faster than 1000 or 1500, this is the grit 69charger says to use after the 1st and second coat. I knew it was a rough grit but I didn't mind stepping back a few steps to get the orange peel out.
It worked fine, and I subsequently applied 2 more coats and wetsanded with 1000, and I just applied the 6th/final coat. Tonight I'll wetsand it with 1500 then polish and post pics.
After sanding with 1000, I put some mineral spirits on a rag and wiped the area. If it looks like that after polishing I'll be very happy.
re the soap in the water, does that help the paper glide easier?
Re: paint job on a budget!? [Re: Exit1965] #21667
02/06/06 10:44 AM
02/06/06 10:44 AM
toronto canada
69chargeryeehaa Offline
toronto canada
-Dave
i haven't tried soap and water, i see no real advantage, i just use straight water and keep the area really wet, using a spray bottle and spray it down alot, after wetsanding for a bit i have a bucket of water and a shammy i whipe down the surface with while it's still wet, that way it's much eaiser to clean before it dries. and as for the mineral spirits on a wet rag and just whiping it down, yes, that's what it looks like polished, even better, just gives you an idea of what it will look like when finished, that's about the first time you really see the results.
Re: paint job on a budget!? [Re: 69chargeryeehaa] #21668
02/06/06 10:49 AM
02/06/06 10:49 AM
Anonymous OP
Anonymous OP
The soap actualy lubricates the paper and it will sand smoother. As far as finish goes I dont think it will make a difference. I have heard it makes the paper last longer though? In any case the main thing is to keep your area saturated. On a side note. I cannot find on the net anywhere where tremclad makes rustoleum and that it is in fact the same product. I was thinking about using valspar tractor and implement enamel from TSC. Any advice or info on that would be great. I was worried about it though because it takes a hardner?
Re: paint job on a budget!? #21669
02/06/06 10:57 AM
02/06/06 10:57 AM
PA
KGorney Offline
KGorney  Offline
PA
The I cannot find on the net anywhere where tremclad makes rustoleum and that it is in fact the same product.
Try here...
http://www.tdwi.org/Publications/WhatWorks/display.aspx?ID=7708
" Used by both professionals and “do-it-yourselfers,” Rust-Oleum’s brands—including Rust-Oleum®, Mono®, Tremclad®, and Varathane®—are widely distributed across Canada through independent hardware stores and large “big-box” retailers such as Wal-Mart, Canadian Tire, Rona, and Home Depot."
