Can some one do some math for me?????? #2164533
09/29/16 06:12 PM
09/29/16 06:12 PM
Washington
madscientist Offline OP
Washington
I'm hoping someone can run some compression ratio numbers for me. I'll supply the data and you do the math. I can't get the numbers to come up with what I think they should be.
Here goes:
4.0705 bore
3.313 stroke
.055 gasket with 4.150 bore
67 cc chamber
110 cc 1/2 inch down fill
Piston is .044 positive out of the bore
Run the numbers and see what you get.
Thanks in advance.
Re: Can some one do some math for me?????? [Re: madscientist] #2164553
09/29/16 06:27 PM
09/29/16 06:27 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
10.65
Re: Can some one do some math for me?????? [Re: madscientist] #2164558
09/29/16 06:33 PM
09/29/16 06:33 PM
Washington
Washington
I get 9.95
I thought it should be 10.8 per so.
It's definitely pissing me off.
Thanks for the math.
Re: Can some one do some math for me?????? [Re: madscientist] #2164561
09/29/16 06:34 PM
09/29/16 06:34 PM
Canada
CTD5.9 Offline
CTD5.9  Offline
Canada
I got 8.69 in the wallace calculator which feels wrong. I don't know the real math behind calculating so I made some guesses.
I went with 3.32 as the valve relief because a 4.0705 x .5 cylinder should be 106.68 CC, the 0.044 into the deck height made me question it.
Maybe it should be -0.044? that would come out to about 10.66
Re: Can some one do some math for me?????? [Re: madscientist] #2164573
09/29/16 06:50 PM
09/29/16 06:50 PM
Washington
Washington
That's one issue I have. The actual downfall is 110 cc's so the flat top piston has valve notches that are about equal to a 3.5 cc dish.
Guess I should have shoved it .060 out of the deck.
Re: Can some one do some math for me?????? [Re: madscientist] #2164574
09/29/16 06:50 PM
09/29/16 06:50 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
10.63
used -3.5cc for the piston dish
-.044 for deck
http://www.csgnetwork.com/compcalc.html
Re: Can some one do some math for me?????? [Re: CTD5.9] #2164582
09/29/16 07:02 PM
09/29/16 07:02 PM
Fredericksburg Va
P
plycuda Offline
plycuda  Offline
P
Fredericksburg Va
I get 8.68 if you do pistons in the hole .044 but out of the hole .044 is 10.65
Re: Can some one do some math for me?????? [Re: madscientist] #2164601
09/29/16 07:28 PM
09/29/16 07:28 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I get 10.68, not accounting for the area above the rings.
Re: Can some one do some math for me?????? [Re: madscientist] #2164615
09/29/16 07:52 PM
09/29/16 07:52 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Piston to head is .011?
Re: Can some one do some math for me?????? [Re: madscientist] #2164631
09/29/16 08:17 PM
09/29/16 08:17 PM
AZ
squirrel Offline
squirrel  Offline
AZ
hopefully it's one of those open chamber heads? I was wondering the same thing...I kind of doubt it's an old open chamber head, with that small of chamber though.
Re: Can some one do some math for me?????? [Re: madscientist] #2164643
09/29/16 08:29 PM
09/29/16 08:29 PM
Real North Cal.
66er Offline
66er  Offline
Real North Cal.
I get 10.72 without accounting for extra bore size of the gasket, so 10.63-10.68 sounds real close to me. I got 3.32 for the valve relief. 1/2" x 4.0705= 106.68cc. Subtract that from your 110cc and you get 3.32
Re: Can some one do some math for me?????? [Re: 66er] #2164687
09/29/16 09:20 PM
09/29/16 09:20 PM
Washington
Washington
That 3.32 is what the DISH Is even though the piston is out of the bore.
The 1/2 inch down fill is 106.59513 so that makes the piston think it's a dish even though it's positive out of the deck.
I'd have to post all my math but I get 9.95 and if that is the case, there was NEVER an actual 10.5:1 340. It's frustrating for sure.
Re: Can some one do some math for me?????? [Re: madscientist] #2164702
09/29/16 09:49 PM
09/29/16 09:49 PM
in the middle
dodger mope Online content
dodger mope  Online Content
in the middle
my moody calculator says 9.55 to 1
Re: Can some one do some math for me?????? [Re: madscientist] #2164738
09/29/16 10:33 PM
09/29/16 10:33 PM
Washington
Washington
We are all using the same numbers with different results.
Unreal.
Re: Can some one do some math for me?????? [Re: madscientist] #2164742
09/29/16 10:38 PM
09/29/16 10:38 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
[s][/s] I guessed at the top ring being down .200" from the top of the piston. The calculated fill volume for your bore is 106.22 cc. 110-106.22=3.88 effective dish. A lot of different answers here for a very important dimension while building an engine. I use the Diamond Pistons calculator.
Instructions: Enter a value in the un-shaded boxes below as they pertain to your engine.
Note: For pistons BELOW the block @ TDC - value in box must be a POSITIVE number (.000)
Note: For pistons ABOVE the block @ TDC - value in box must be a NEGATIVE number (-.000)
Note: For a DISH piston - value in box must be a POSITIVE number (0.0)
Note: For a DOME piston - value in box must be a NEGATIVE number (-0.0)
Note: Manipulate the DOME/DISH & PISTON to DECK volumes to get the ratio you want.
Enter the number of cylinders of your engine
8
Bore
Finished bore of your engine
4.0405
Stroke
Stroke of your engines crankshaft
3.313
Rod Length
Ctr. to Ctr. length of your connecting rods
Gasket Bore
Head Gasket bore diameter
4.150
Comp. Gasket
Compressed Head Gasket thickness
.055
Block Deck Height
Center of main bearing bore to top of block
0
Top Ring Down
Top of 1st ring to top of pistons (FLAT)
.200
Chamber Volume
Cylinder Head chamber volume in CC's
67
Dome/Dish Volume
DOME (-) or DISH (+) vol. (theoretical) in CC's
3.78
Piston to Deck
Top of BLOCK to top of piston (FLAT) @ TDC
-.044
Click "Calculate" for dimension results.
Calculate
Total Volume
770.01
Cylinder Volume
Total cylinder volume in CC's =
696.14
Clearance Volume
All effective vol. above block deck @ TDC in CC's =
73.87
Gasket Volume
Volume of your head gasket in CC's =
12.19
Top Ring Volume
Total volume above the top ring @ TDC in CC's =
0.79
Deck Volume
Volume of area above the pistons @ TDC in CC's =
-9.24
Piston Top Land
Piston top land diameter for volume calculations =
4.002
1/2 Stroke
1/2 stroke of your engine's crankshaft in inches =
1.657
Compression Ht.
Ctr. of piston pin to top of piston (FLAT) in inches =
NaN
Cubic Inches
Cubic inch displacement of your engine =
339.84
For the given dimensions, your compression ratio =
10.44
Re: Can some one do some math for me?????? [Re: madscientist] #2164762
09/29/16 11:02 PM
09/29/16 11:02 PM
Try using the 3.32 CC for the valve relief inputs and use a flat top piston above the deck for the rest of the math scope up the last two 340 NHRA legal stocker motors I built ended up with right at 11.56 to 1 measured compression ratios shruggy
Re: Can some one do some math for me?????? [Re: madscientist] #2164768
09/29/16 11:07 PM
09/29/16 11:07 PM
Washington
Washington
Can you run my numbers they way you are talking about and tell me what you get?
Like I said, I get 9.95:1 and when I get some time tonight I'll post my math to verify. I'm not too concerned with crevice volume at this point.
I guess my other question is what happens at an NHRA event and you have a pull apart your engine after you set a record or something. Does NHRA calculate crevice volume? Do they just drop the piston .500 and do a down fill and calculate the CR?
I have done the down fill for years and for some reason, I'm way off the reservation on this.
Re: Can some one do some math for me?????? [Re: madscientist] #2164777
09/29/16 11:19 PM
09/29/16 11:19 PM
I'll bet money that NHRA will use the measured deck hieght or above deck measurments from the manufactures blue print specs along with the head gasket thickness and if your total measurements don't exceed the stock specs your golden up devil Hence the 426 street Hemi motors in both stock and SS getting away with round top pistons that calculate out to have 12.+ to 1 compression ratios using the one inch down fill volume methods work shruggy
Re: Can some one do some math for me?????? [Re: madscientist] #2164990
09/30/16 10:18 AM
09/30/16 10:18 AM
Northeast Indiana
73DAD Offline
73DAD  Offline
Northeast Indiana
I got exactly the same as the first reply 10.65366:1
Re: Can some one do some math for me?????? [Re: 73DAD] #2165004
09/30/16 11:09 AM
09/30/16 11:09 AM
Romulus, MI
GTS340 Offline
GTS340  Offline
Romulus, MI
Im sure rounding errors come in to play depending on what calculator is used
