Can some one do some math for me??????
#2164533
09/29/16 06:12 PM
09/29/16 06:12 PM
Posts: 4,457 Washington
madscientist
Washington
I'm hoping someone can run some compression ratio numbers for me. I'll supply the data and you do the math. I can't get the numbers to come up with what I think they should be.
Here goes: 4.0705 bore 3.313 stroke .055 gasket with 4.150 bore 67 cc chamber 110 cc 1/2 inch down fill Piston is .044 positive out of the bore
Run the numbers and see what you get.
Thanks in advance.
Re: Can some one do some math for me??????
[Re: madscientist]
#2164558
09/29/16 06:33 PM
09/29/16 06:33 PM
madscientist
Washington
I get 9.95
I thought it should be 10.8 per so.
It's definitely pissing me off.
Thanks for the math.
[Re: madscientist]
#2164573
09/29/16 06:50 PM
09/29/16 06:50 PM
madscientist
Washington
That's one issue I have. The actual downfall is 110 cc's so the flat top piston has valve notches that are about equal to a 3.5 cc dish.
Guess I should have shoved it .060 out of the deck.
[Re: CTD5.9]
#2164582
09/29/16 07:02 PM
09/29/16 07:02 PM
Posts: 653 Fredericksburg Va
plycuda
Fredericksburg Va
I got 8.69 in the wallace calculator which feels wrong. I don't know the real math behind calculating so I made some guesses. I went with 3.32 as the valve relief because a 4.0705 x .5 cylinder should be 106.68 CC, the 0.044 into the deck height made me question it. Maybe it should be -0.044? that would come out to about 10.66 I get 8.68 if you do pistons in the hole .044 but out of the hole .044 is 10.65
[Re: madscientist]
#2164601
09/29/16 07:28 PM
09/29/16 07:28 PM
fast68plymouth
So. Burlington, Vt.
I get 10.68, not accounting for the area above the rings.
[Re: 66er]
#2164687
09/29/16 09:20 PM
09/29/16 09:20 PM
madscientist
Washington
I get 10.72 without accounting for extra bore size of the gasket, so 10.63-10.68 sounds real close to me. I got 3.32 for the valve relief. 1/2" x 4.0705= 106.68cc. Subtract that from your 110cc and you get 3.32 That 3.32 is what the DISH Is even though the piston is out of the bore. The 1/2 inch down fill is 106.59513 so that makes the piston think it's a dish even though it's positive out of the deck. I'd have to post all my math but I get 9.95 and if that is the case, there was NEVER an actual 10.5:1 340. It's frustrating for sure.
[Re: madscientist]
#2164738
09/29/16 10:33 PM
09/29/16 10:33 PM
madscientist
Washington
We are all using the same numbers with different results.
Unreal.
[Re: madscientist]
#2164768
09/29/16 11:07 PM
09/29/16 11:07 PM
madscientist
Washington
Can you run my numbers they way you are talking about and tell me what you get?
Like I said, I get 9.95:1 and when I get some time tonight I'll post my math to verify. I'm not too concerned with crevice volume at this point.
I guess my other question is what happens at an NHRA event and you have a pull apart your engine after you set a record or something. Does NHRA calculate crevice volume? Do they just drop the piston .500 and do a down fill and calculate the CR?
I have done the down fill for years and for some reason, I'm way off the reservation on this.
[Re: madscientist]
#2164777
09/29/16 11:19 PM
09/29/16 11:19 PM
Posts: 43,307 Bend,OR USA
Cab_Burge
