Re: Valve Length BB Victors
[Re: 1fastabody]
#2162772
09/27/16 01:33 PM
09/27/16 01:33 PM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
It's not easy with the stock length valves, but can be done. If you use longer valves, you will likely have to re-locate the rocker arm shaft location?
On the last set of Victors, we got valve spring locators from PAC that were machined down from 0.060" thick, to 0.030" thick, and use +0.100 valve spring retainers. My cylinder head guy assembled these, so I don't have the exact measurements. I think all the parts (springs, locators, retainers were from PAC?) FWIW, We used the PAC 1326 valve springs too.
[Re: 1fastabody]
#2162914
09/27/16 04:43 PM
09/27/16 04:43 PM
Posts: 153 Wildwood, FL
1fastabody
Wildwood, FL
Thanks, I've read through those articles and they have some very good info. But I'm still looking to see if any knows what length valves they are running. I know I have to work some magic to get that 2" installed height.
Innovative Performance
[Re: LaRoy Engines]
#2163413
09/28/16 02:38 AM
09/28/16 02:38 AM
Posts: 9,100 Rogue River, OR
Jeremiah
Rogue River, OR
I have used the stock Victor 5.375" length .250" tip exhaust valve and a 5.344" intake .250" tip to get 2.00" or more installed height and go right at .800" lift. I do recommend relocating the rocker shaft. Listen to this guy! If you wanted to go to a longer vlave that would help the geometry some however you are still likely to run into retainer to rocker clearance if the shaft is not relocated away from the valves. Ferrera has longer valves for -1' that could be made to work. +.100 would probably get you to .800 lift. Don't forget to account for the slightly shorter intake valve.
[Re: 1fastabody]
#2163507
09/28/16 10:10 AM
09/28/16 10:10 AM
1fastabody
Wildwood, FL
I was looking at possible running the Ferrea hollow stem valves. The ones I was looking at were Intake #F1050P 2.250 dia. 5.471 length .250 tip Exhaust #F1051P 1.88 dia 5.450 length .250 tip Do you see any issues with using these? Note, I will be relocating the shaft to correct alignment. Thanks for the input guys.
[Re: Jeremiah]
#2166406
10/02/16 01:20 PM
10/02/16 01:20 PM
Posts: 561 USA
B3RE
USA
I have used the stock Victor 5.375" length .250" tip exhaust valve and a 5.344" intake .250" tip to get 2.00" or more installed height and go right at .800" lift. I do recommend relocating the rocker shaft. Listen to this guy! If you wanted to go to a longer vlave that would help the geometry some however you are still likely to run into retainer to rocker clearance if the shaft is not relocated away from the valves. Ferrera has longer valves for -1' that could be made to work. +.100 would probably get you to .800 lift. Don't forget to account for the slightly shorter intake valve. Jeremiah, I'm baffled. After the work we did on your geometry, I don't understand how you feel a longer valve would help geometry, when in fact, it is exactly the opposite. Relocating the shafts is not so much to correct the lateral position, but rather, correcting the height of the shaft centerline. Since it is already too low with a stock length valve, a longer valve would make it that much lower in relation to the valve tip.
Mike Beachel
I didn't write the rules of math nor create the laws of physics, I am just bound by them.
[Re: 1fastabody]
#2167198
10/03/16 06:23 PM
10/03/16 06:23 PM
1fastabody
Wildwood, FL
Jeremiah, I'm planning on having them CNC. I hoping to get around 400 cfm.
Mike, If I run this longer valve would raising the shaft screw up my geometry?
[Re: 1fastabody]
#2167237
10/03/16 07:18 PM
10/03/16 07:18 PM
Posts: 561 USA
B3RE
USA
No sir, even with the standard length valve, the shaft needs to be raised and offset for proper geometry, which improves clearance issues also. Putting a longer valve in the head would require the shaft to be raised even more. That's why I run the shortest valve possible for a given combination. As long as you can get the net valve lift, and still have about .060" coil bind clearance, that will be longest valve and tallest installed height you need.
Mike Beachel
[Re: 1fastabody]
#2167510
10/04/16 03:17 AM
10/04/16 03:17 AM
451Mopar
Aurora, Colorado
Mike, If I run this longer valve would raising the shaft screw up my geometry? The Hughes CNC "Monster Max wedge" is right at 400 cfm. I had my heads flowed on a stingy bench with a smaller bore and they still flowed very well, and that is with the roughness from the CNC machining too. I think if the ports were finished with some sandpaper rolls to smooth out the CNC finish, they would flow even more?
