Original paint #2161568
09/25/16 08:18 PM
09/25/16 08:18 PM
gainsville, usa
johnfin Offline OP
johnfin  Offline OP
gainsville, usa
Getting ready to paint my car and was wondering if I should use the 2 part urethane or the original enamel. Its over 50 years old and still polishes up in spots so I am wondering about clear top finish. When it goes the whole thing needs to be redone. I have a 2004 chevy that the blue roof started to haze. Paint shop had to redo the complete roof down to metal. So if I decide to go base coat/clear coat, am I able to do the jambs and engine compartment with enamel (super cheap) or would flaring it into the base coat be tricky?
Re: Original paint [Re: johnfin] #2161620
09/25/16 10:16 PM
09/25/16 10:16 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
You can spray the jambs and trunk, engine compartment in acrylic enamel and backtape them when you shoot the BC/CC.
Nautilus Racing-
Re: Original paint [Re: johnfin] #2162027
09/26/16 02:25 PM
09/26/16 02:25 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Why not do the whole car in enamel? I've done a few full cars in acrylic urethane single stage and I like it, has more gloss than enamel.
Re: Original paint [Re: DaytonaTurbo] #2162230
09/26/16 06:41 PM
09/26/16 06:41 PM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
Did our 300 B in single stage Deltron in 1986, came out spectacular, depth and gloss like a fine 2 stage and 30 years later not a single flaw, crack, rock chip, etc. Extremely resistant to scratching or rocks. Inner front fender panels behind front wheels still perfect.
Re: Original paint [Re: johnfin] #2162529
09/27/16 02:14 AM
09/27/16 02:14 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Better do it soon as single stage enamel is getting very hard to find
