Page 13 of 20 1 2 11 12 13 14 15 19 20
Re: Moparts official power adder thread [Re: tboomer] #2159398
09/22/16 01:32 PM
09/22/16 01:32 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Chip......I would likely put bungs on there and use an Annular nozzle.
Outlawd.....you have EFI, why are you not running DRY nitrous
Re: Moparts official power adder thread [Re: Monte_Smith] #2159493
09/22/16 04:02 PM
09/22/16 04:02 PM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
Good question Monte. I have plenty of injector and fuel pump, and I have calibration input for adding/removing fuel when N2O is activated, however, the input is a % shift, not a fixed flow, so I was struggling with how to figure out the best way to equate flow to a %, but I think I have it figured out now.
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: Moparts official power adder thread [Re: tboomer] #2159510
09/22/16 04:37 PM
09/22/16 04:37 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Should be easy, even if you don't have direct power adder tables.......Lets use some random numbers. Let say your total fuel flow is 400lb/hr and you need an extra 100lb/hr for the nitrous. That's a 25% increase in total fuel flow. Now of course you will likely need to ramp that in based on time, rpm, something........or have a separate fuel table with 25% added starting at any rpm above where nitrous comes on
Re: Moparts official power adder thread [Re: Monte_Smith] #2161777
09/26/16 02:23 AM
09/26/16 02:23 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
To recap, what AFR am I looking for on nitrous? My notes say 12.8-13.0 should be really close. I'm questioning this after one of the been there done that types told be target should be high 11's, low 12's and quoted a HotRod magazine article.
Anyone?
I do understand that the engine should run it's best number with the safe AFR with or without the nitrous.
Re: Moparts official power adder thread [Re: tboomer] #2161797
09/26/16 03:31 AM
09/26/16 03:31 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Basically the "been there done that guy" and the Hot Rod article are wrong
Re: Moparts official power adder thread [Re: tboomer] #2161938
09/26/16 12:31 PM
09/26/16 12:31 PM
Suffolk County, New York
1mean340 Offline
1mean340  Offline
To my fellow mopar forced induction enthusiasts....
As I near completion of my procharged small block build, I am having some conflicting thoughts on how to go about getting her ready for tuning. On a brand new build do you guys generally ease into the boost by tuning for lower boost levels first and then moving up to higher, or do you normally just throw all the boost you plan to run at the motor, tune it once and be done with it?
I was thinking of ordering a pulley that will put me somewhere around 7-8psi at first to be a little more on the safe side with the new setup and then swapping to a 15 or so psi pulley once I know that is all working well. I don't know if it's really worth it though, or if I should just save money and time by going straight to the 15psi pulley.
Here is what I'm building up: 69 340 block bored .030 over. Speed Pro pistons (machinist is cutting a small dish into them, he insists there will be more than enough meat to keep it safe from detonation), factory forged crank, main studs, hughes girdle, Eagle H beams, ported w2 econo flowing around 300cfm, head studs and cometic gaskets ported indy 360 intake, solid roller (somewhere in the 250 intake duration range) front mount intercooler, D1SC procharger. Car will run E85 through Fitech 8 fuel injection. A1000 fuel system. I'll be controlling timing through the FItech system using a locked out MSD Billet distributor. FItech has built in wideband for tuning. Hoping we can get the C/R down to 9.5 tops, hopefully a little less.
My goal is to be able to touch 9's in my full interior E body with 4:10 rear once I get the tuning/chassis all worked out. I just don't want to blow it up trying and I know I'll be close.
Re: Moparts official power adder thread [Re: Monte_Smith] #2162090
09/26/16 03:40 PM
09/26/16 03:40 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
So my initial statement is loosely correct?
Re: Moparts official power adder thread [Re: tboomer] #2229668
01/07/17 08:50 PM
01/07/17 08:50 PM
USA
hudsonhornet7x Online content
hudsonhornet7x  Online Content
USA
The Hellcat supercharger uses a electric throttle body as a bypass when not building boost. A regular supercharger uses a vacuum bypass I believe. I am looking for ideas on what would be needed to either run the electric bypass or retrofit a vacuum unit.
The pic is showing the bypass itself for reference.
Thanks for any help as this is the last hurdle to make our swap work.
dodge-370ci-v-8-supercharged-hellcat-hemi-engine-bypass-valve-repurposed-throttle-body.jpg
Re: Moparts official power adder thread [Re: tboomer] #2250061
02/09/17 12:28 AM
02/09/17 12:28 AM
San Diego CA
65 Hemi Offline
65 Hemi  Offline
San Diego CA
Anybody running a 118 turbo? I just picked one up for my 582 hemi. I know it's not the ideal combo but I want to try it. Any feedback would be much appreciated.
Doug
MOPAR or NO CAR!!!
1965 Dodge Coronet soon a 6.1 Hemi with a Magnson blower 810 hp on pump gas
1964 Dodge Polara 582" Indy alum Block 426-1RA heads,
1933 Plymouth PE all Steel, LT1 4L60E
1959 Plymouth Savoy 33,000 mile survivor
Old cars are never done. They are ongoing projects!
Re: Moparts official power adder thread [Re: 65 Hemi] #2250158
02/09/17 02:46 AM
02/09/17 02:46 AM
Oakville, Wa
HOTMOPR Offline
HOTMOPR  Offline
Oakville, Wa
Its gonna work just fine!
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
Re: Moparts official power adder thread [Re: 65 Hemi] #2250248
02/09/17 11:43 AM
02/09/17 11:43 AM
an8sec70cuda Offline
Pretty sure Jason Digby runs a 118 mm turbo on his Predator motor...the black dart that reset the leaf spring world record a few weeks ago in the 4.20s 1/8 mile.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Moparts official power adder thread [Re: tboomer] #2290094
04/18/17 03:54 PM
04/18/17 03:54 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
The exhaust wheel and housing needs to be the biggest you can get. I run a 106mm turbo on an Indy -1 motor.
This power adder section should be named after Monte
Re: Moparts official power adder thread [Re: tboomer] #2290499
04/19/17 11:22 AM
04/19/17 11:22 AM
Let's talk about nitrous progressives...which do yall use and/or like?
I agree this should be named for Monte...wish it had enough traffic for a separate forum.
CHIP
Re: Moparts official power adder thread [Re: an8sec70cuda] #2291169
04/20/17 07:21 PM
04/20/17 07:21 PM
NC
O
onefastindy Offline
onefastindy  Offline
O
NC
I've got the leash controller
Re: Moparts official power adder thread [Re: onefastindy] #2291301
04/20/17 11:23 PM
04/20/17 11:23 PM
On the parachute mount
N
n20mstr Online content
n20mstr  Online Content
N
Is that pic on fast your car on the bumper ?
....BAD A$$ STREET CAR.....
Re: Moparts official power adder thread [Re: an8sec70cuda] #2291306
04/20/17 11:29 PM
04/20/17 11:29 PM
N
N
All I got is an edelbrock......
Re: Moparts official power adder thread [Re: tboomer] #2291315
04/20/17 11:40 PM
04/20/17 11:40 PM
baldwinsville new york
a493demon Offline
a493demon  Offline
yes it's scotts on the bumper
Moparts - Monte Smith Official Power Adder Thread [Re: a493demon] #2291318
04/20/17 11:44 PM
04/20/17 11:44 PM
N
N
The proper gear will do more for that than anything else, monte told me so...lol I thought it would never work but it does
Moparts - Monte Smith Official Power Adder Thread [Re: an8sec70cuda] #2291319
04/20/17 11:45 PM
04/20/17 11:45 PM
N
N
Sure !
Moparts - Monte Smith Official Power Adder Thread [Re: tboomer] #2291350
04/21/17 12:34 AM
04/21/17 12:34 AM
a493demon Offline
a493demon  Offline
leash here
