Re: Carter avs carbs
[Re: johnfin]
#2159180
09/22/16 12:24 AM
09/22/16 12:24 AM
RapidRobert
"a/c" Did you mean "AVS"? If so, AFAIK the auto has a long horizontle throttle pin (for the slotted kickdown rod) & a manual app has a short one
[Re: Jim_Lusk]
#2159191
09/22/16 12:52 AM
09/22/16 12:52 AM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
S There were possible differences in metering rods and jet sizes and clusters may have also been different. That would be correct.
[Re: johnfin]
#2159353
09/22/16 12:58 PM
09/22/16 12:58 PM
Posts: 8,290 fredericksburg,va
cudaman1969
fredericksburg,va
AC carbs had hot idle compensators. Not sure if jets and rods, idle feed restrictions are the different between manual and auto, all have the same size throttle, ventura (340-383 one size, 440 bigger). I picked up a few more and I have a 69 383 manual and auto carb, I'll check for differences. One thing I found different, 68 383 stick has holes in the primary blades and the 69 doesn't. Looks stock, not buggered up.
[Re: johnfin]
#2159704
09/22/16 10:00 PM
09/22/16 10:00 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Paging your service manual, which would detail all that out.
My 70 FSM shows a difference between manual and automatic AVS'.
It also lists, for autos only, a separate listing for with AC and without, but the specs are identical, they do have different part numbers, but that must be for the assembly WITH the idle compensator..
