Carter avs carbs #2159136
09/21/16 11:41 PM
09/21/16 11:41 PM
gainsville, usa
johnfin Offline OP
johnfin  Offline OP
gainsville, usa
Other then the kick down shaft linkage...what is the difference between the a/c carb..the manual...and the automatic?
Re: Carter avs carbs [Re: johnfin] #2159180
09/22/16 12:24 AM
09/22/16 12:24 AM
"a/c" Did you mean "AVS"? If so, AFAIK the auto has a long horizontle throttle pin (for the slotted kickdown rod) & a manual app has a short one
Re: Carter avs carbs [Re: johnfin] #2159185
09/22/16 12:32 AM
09/22/16 12:32 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Some carbs had a blow-off valve between the secondary throttle bores, others did not (not sure of the exact applications - I'd have to look at all of mine). There were possible differences in metering rods and jet sizes and clusters may have also been different.
Re: Carter avs carbs [Re: Jim_Lusk] #2159191
09/22/16 12:52 AM
09/22/16 12:52 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Originally Posted By Jim_Lusk
S There were possible differences in metering rods and jet sizes and clusters may have also been different.
That would be correct.
Re: Carter avs carbs [Re: johnfin] #2159353
09/22/16 12:58 PM
09/22/16 12:58 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
AC carbs had hot idle compensators. Not sure if jets and rods, idle feed restrictions are the different between manual and auto, all have the same size throttle, ventura (340-383 one size, 440 bigger). I picked up a few more and I have a 69 383 manual and auto carb, I'll check for differences. One thing I found different, 68 383 stick has holes in the primary blades and the 69 doesn't. Looks stock, not buggered up.
Re: Carter avs carbs [Re: johnfin] #2159672
09/22/16 09:11 PM
09/22/16 09:11 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Paging Scott Smith
Re: Carter avs carbs [Re: johnfin] #2159704
09/22/16 10:00 PM
09/22/16 10:00 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Paging your service manual, which would detail all that out.
My 70 FSM shows a difference between manual and automatic AVS'.
It also lists, for autos only, a separate listing for with AC and without, but the specs are identical, they do have different part numbers, but that must be for the assembly WITH the idle compensator..
Don't be the exception.
Re: Carter avs carbs [Re: johnfin] #2159731
09/22/16 10:28 PM
09/22/16 10:28 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Supercuda (and others) pretty much covered it.
The question I would ask the OP is;
What are your goals in asking that question?
Re: Carter avs carbs [Re: Supercuda] #2159872
09/23/16 02:02 AM
09/23/16 02:02 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
There are a lot of differences depending on application.
