Aftermarket intakes and engine dress up
#2155481
09/16/16 01:09 AM
09/16/16 01:09 AM
Posts: 18,575 Dreaming of the 808
AZ_A12_BEE
Dreaming of the 808
In the process of purchasing this brand new crate 6.4 Hemi, I plan on using a truck front cover so I can put the accessories up high, this cover won't allow me to use the intake on this motor so what are my options? Any aftermarket intakes that might work?
Also, is there anyway to dress up the motor with more chrome to eliminate the plastic and make it look more "old school"?
69.5 A12 Bee, first purchased in 1976, car 169 on registry
69 Coronet R/T 440/4 spd
69 Coronet 500 Conv H code 383 4bbl/auto
37 Plymouth PU
Find your spot on earth and ride it.
Re: Aftermarket intakes and engine dress up
[Re: AZ_A12_BEE]
#2155513
09/16/16 02:19 AM
09/16/16 02:19 AM
Posts: 4,302 Nebraska
72Swinger
Nebraska
What are you putting it in? I have car acc in my Dart and there are a few B and E bodies doing the same. There are truck 6.4's out there.
Mopar to the bone!!!
[Re: 72Swinger]
#2156017
09/17/16 12:15 AM
09/17/16 12:15 AM
AZ_A12_BEE
Dreaming of the 808
What are you putting it in? I have car acc in my Dart and there are a few B and E bodies doing the same. There are truck 6.4's out there. It's going onto my 1937 Plymouth pickup, I need the accessories higher instead of wider
37 Plymouth PU
[Re: ntstlgl1970]
#2156018
09/17/16 12:16 AM
09/17/16 12:16 AM
AZ_A12_BEE
Dreaming of the 808
The truck front cover really limits the intake choices to truck intakes or 4bbl style. If you have the room, can you reverse the intake? For dress up, there are some aftermarket valve covers, but they can be pretty pricey. Try shophemi.com You can reverse the intake?
37 Plymouth PU
[Re: AZ_A12_BEE]
#2156071
09/17/16 03:52 AM
09/17/16 03:52 AM
72Swinger
Nebraska
That is definitely a good reason for the truck acc drive, that or turbo's.
[Re: AZ_A12_BEE]
#2157242
09/19/16 09:12 AM
09/19/16 09:12 AM
Posts: 4,254 Canada
WO23Coronet
Canada
If you want carbs, your truck would really suit the Edelbrock 2x4bbl intake as well
Edit:I think the Edelbrock intake is only for early 5.7 heads
[Re: Hemijoejr]
#2157884
09/20/16 12:50 AM
09/20/16 12:50 AM
AZ_A12_BEE
Dreaming of the 808
Is that a carb or fuel injection manifold? I would like chrome valve covers, or ways to get rid of the plastic
37 Plymouth PU
[Re: AZ_A12_BEE]
#2159125
09/21/16 11:33 PM
09/21/16 11:33 PM
Posts: 29 NJ, USA
Hemijoejr
NJ, USA
Sorry for the delay!! My car has had an engine swap now for almost 10 years. Here are a few pics of my engine compartment. The first pic is a built early 5.7L with my sheet metal cross ram. The second pic is a stockish early 5.7L for R&D with my intake. [img:left]http:// [/img] [img:left]http:// [/img]
Stock Displacement, pump gas, 5.7L Gen 3 Hemi, early 5.7L heads, 3670lbs with driver, Best time and MPH 11.11@120.9MPH
[Re: Hemijoejr]
#2160310
09/23/16 06:38 PM
09/23/16 06:38 PM
Posts: 491 South Dakota
kilo1
South Dakota
Joe, here is the deal love your Intake Manifolds But want more than just a dual plane for the stroker 6.4 I am building But as you know the Weber/ritter drag pak intake is too much for street due to torque loss on low end , I will be running Nitrous occasionally . Any plans on making one ?
USMC 1982-1988 GM Parts 1988 -2006 US Army 2006-2015
[Re: AZ_A12_BEE]
#2160380
09/23/16 08:20 PM
09/23/16 08:20 PM
Posts: 29 NJ, USA
Hemijoejr
NJ, USA
I am working on a prototype crossram/tunnel ram hybrid that has 8.5" long runners and uses Holley Hi-Ram tops. I do have a prototype in a sheet metal being made but the cast aluminum version won't be available for a while. All I can say right now is stay tuned. I'm working on it.
[Re: Hemijoejr]
#2160409
09/23/16 09:02 PM
09/23/16 09:02 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
I am working on a prototype crossram/tunnel ram hybrid that has 8.5" long runners and uses Holley Hi-Ram tops. I do have a prototype in a sheet metal being made but the cast aluminum version won't be available for a while. All I can say right now is stay tuned. I'm working on it. Dual Edelbrocks here I come
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: AZ_A12_BEE]
#2160489
09/23/16 10:37 PM
09/23/16 10:37 PM
72Swinger
Nebraska
How would a "Rat Roaster" style intake stack up I wonder?
