Aftermarket intakes and engine dress up #2155481
09/16/16 01:09 AM
09/16/16 01:09 AM
Dreaming of the 808
AZ_A12_BEE Offline OP
Dreaming of the 808
In the process of purchasing this brand new crate 6.4 Hemi, I plan on using a truck front cover so I can put the accessories up high, this cover won't allow me to use the intake on this motor so what are my options? Any aftermarket intakes that might work?
Also, is there anyway to dress up the motor with more chrome to eliminate the plastic and make it look more "old school"?
69.5 A12 Bee, first purchased in 1976, car 169 on registry 69 Coronet R/T 440/4 spd 69 Coronet 500 Conv H code 383 4bbl/auto 37 Plymouth PU Find your spot on earth and ride it.
Re: Aftermarket intakes and engine dress up [Re: AZ_A12_BEE] #2155513
09/16/16 02:19 AM
09/16/16 02:19 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
What are you putting it in? I have car acc in my Dart and there are a few B and E bodies doing the same. There are truck 6.4's out there.
Mopar to the bone!!!
Re: Aftermarket intakes and engine dress up [Re: AZ_A12_BEE] #2155629
09/16/16 11:38 AM
09/16/16 11:38 AM
Sac, CA, USA
N
ntstlgl1970 Offline
ntstlgl1970  Offline
N
Sac, CA, USA
The truck front cover really limits the intake choices to truck intakes or 4bbl style. If you have the room, can you reverse the intake? For dress up, there are some aftermarket valve covers, but they can be pretty pricey. Try shophemi.com
Re: Aftermarket intakes and engine dress up [Re: 72Swinger] #2156017
09/17/16 12:15 AM
09/17/16 12:15 AM
Dreaming of the 808
Dreaming of the 808
It's going onto my 1937 Plymouth pickup, I need the accessories higher instead of wider
Re: Aftermarket intakes and engine dress up [Re: ntstlgl1970] #2156018
09/17/16 12:16 AM
09/17/16 12:16 AM
Dreaming of the 808
Dreaming of the 808
You can reverse the intake?
Re: Aftermarket intakes and engine dress up [Re: AZ_A12_BEE] #2156066
09/17/16 03:26 AM
09/17/16 03:26 AM
Sac, CA, USA
N
ntstlgl1970 Offline
ntstlgl1970  Offline
N
Sac, CA, USA
Pretty sure you can. Surprised no one has tried it yet. On a car engine, you may have to relocate the heater hard water tubes that run under the intake. Plus whatever harness and fuel line adjustments to avoid interference.
Re: Aftermarket intakes and engine dress up [Re: AZ_A12_BEE] #2156071
09/17/16 03:52 AM
09/17/16 03:52 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
That is definitely a good reason for the truck acc drive, that or turbo's.
Re: Aftermarket intakes and engine dress up [Re: AZ_A12_BEE] #2156393
09/17/16 07:39 PM
09/17/16 07:39 PM
NJ, USA
Hemijoejr Offline
Hemijoejr  Offline
NJ, USA
You could try this for an intake if you wish. http://www.modernmusclextreme.com/p-49-hemi-performance-intake-by-ocperformance.aspx What do you want do engine dress up wise?
Stock Displacement, pump gas, 5.7L Gen 3 Hemi, early 5.7L heads, 3670lbs with driver, Best time and MPH 11.11@120.9MPH
Re: Aftermarket intakes and engine dress up [Re: Hemijoejr] #2156471
09/17/16 10:06 PM
09/17/16 10:06 PM
USA
hudsonhornet7x Offline
USA
Excellent intake for what you have in mind. Made by a good guy too!
Re: Aftermarket intakes and engine dress up [Re: AZ_A12_BEE] #2157242
09/19/16 09:12 AM
09/19/16 09:12 AM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
If you want carbs, your truck would really suit the Edelbrock 2x4bbl intake as well
Edit:I think the Edelbrock intake is only for early 5.7 heads
Re: Aftermarket intakes and engine dress up [Re: Hemijoejr] #2157884
09/20/16 12:50 AM
09/20/16 12:50 AM
Dreaming of the 808
Dreaming of the 808
Is that a carb or fuel injection manifold? I would like chrome valve covers, or ways to get rid of the plastic
Re: Aftermarket intakes and engine dress up [Re: AZ_A12_BEE] #2157919
09/20/16 01:50 AM
09/20/16 01:50 AM
USA
USA
You can order that manifold any way you wish, it will work with carbs or efi.
Re: Aftermarket intakes and engine dress up [Re: hudsonhornet7x] #2157947
09/20/16 04:26 AM
09/20/16 04:26 AM
SE PA
Yellow Fever Offline
SE PA
If you want to sell the stock intake.... whistling
Re: Aftermarket intakes and engine dress up [Re: AZ_A12_BEE] #2159125
09/21/16 11:33 PM
09/21/16 11:33 PM
NJ, USA
Hemijoejr Offline
Hemijoejr  Offline
NJ, USA
Sorry for the delay!! My car has had an engine swap now for almost 10 years. Here are a few pics of my engine compartment. The first pic is a built early 5.7L with my sheet metal cross ram. The second pic is a stockish early 5.7L for R&D with my intake.
[img:left]http://[/img]
Re: Aftermarket intakes and engine dress up [Re: Hemijoejr] #2160310
09/23/16 06:38 PM
09/23/16 06:38 PM
South Dakota
kilo1 Offline
kilo1  Offline
South Dakota
Joe, here is the deal love your Intake Manifolds But want more than just a dual plane for the stroker 6.4 I am building But as you know the Weber/ritter drag pak intake is too much for street due to torque loss on low end , I will be running Nitrous occasionally . Any plans on making one ?
USMC 1982-1988
GM Parts 1988 -2006
US Army 2006-2015
Re: Aftermarket intakes and engine dress up [Re: AZ_A12_BEE] #2160380
09/23/16 08:20 PM
09/23/16 08:20 PM
NJ, USA
Hemijoejr Offline
Hemijoejr  Offline
NJ, USA
I am working on a prototype crossram/tunnel ram hybrid that has 8.5" long runners and uses Holley Hi-Ram tops. I do have a prototype in a sheet metal being made but the cast aluminum version won't be available for a while. All I can say right now is stay tuned. I'm working on it.
Re: Aftermarket intakes and engine dress up [Re: Hemijoejr] #2160409
09/23/16 09:02 PM
09/23/16 09:02 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
Dual Edelbrocks here I come
Re: Aftermarket intakes and engine dress up [Re: AZ_A12_BEE] #2160489
09/23/16 10:37 PM
09/23/16 10:37 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
How would a "Rat Roaster" style intake stack up I wonder?
Re: Aftermarket intakes and engine dress up [Re: AZ_A12_BEE] #2162674
09/27/16 11:29 AM
09/27/16 11:29 AM
South Dakota
kilo1 Offline
kilo1  Offline
South Dakota
Valve cover wise there are these
USMC 1982-1988
GM Parts 1988 -2006
US Army 2006-2015
