can 5.7 and 6.1 front acc. locations be changed on all hemis #2148043
09/05/16 03:33 PM
09/05/16 03:33 PM
Escondido, CA. Ron Podsiadly,...
Mopar Ron Offline OP
I am looking towards a future project .
installing a 5.7-6.1 into a street rod and wondered if the front accessory brackets are interchangeable between all the engines.
I would like to put the air and alt up high on the engine as to avoid clearance problems with the frame and steering shaft
here are a few pics of different configurations
I would think that are all compatible but you never know...
more like these top 2.
things are pretty tight to the engine
the bottom picture looks like I might have
clearance issues with hood side panels or frame...
Screen shot 2016-09-05 at 9.05.36 AM.pngScreen shot 2016-09-05 at 9.07.26 AM.pngScreen shot 2016-09-05 at 8.46.51 AM.png
Re: can 5.7 and 6.1 front acc. locations be changed on all hemis [Re: Mopar Ron] #2148059
09/05/16 03:57 PM
09/05/16 03:57 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
1st and second are off a truck third is off a car.
Both timing covers are interchangeable.
Matt
Re: can 5.7 and 6.1 front acc. locations be changed on all hemis [Re: Mopar Ron] #2148068
09/05/16 04:10 PM
09/05/16 04:10 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Timing covers are interchangeable but car cover accessories are -not- compatible with truck cover accessories.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: can 5.7 and 6.1 front acc. locations be changed on all hemis [Re: GoodysGotaCuda] #2148100
09/05/16 04:52 PM
09/05/16 04:52 PM
eek well that sucks.
so if I buy a 6.1 from a car and want to move the
alt and air up(if they interfere with the frame) I will need to get a truck timing cover and air
unit and a different alt? mad down
Re: can 5.7 and 6.1 front acc. locations be changed on all hemis [Re: Mopar Ron] #2148106
09/05/16 04:57 PM
09/05/16 04:57 PM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Yessir, that's correct. I bought a truck motor and wanted a car cover, been there, done that. Also, the truck timing cover will likely not allow for a car [front] throttle body location, you may be limited to the truck [top] throttle body location which may or may not be what you're looking for.
For what it's worth, I have a truck timing cover, non-eagle 5.7L truck intake manifold and a truck a/c compressor I will not be using. The intake port size will be smaller on the 5.7L intake when compared to the 6.1L head, you would likely want to hunt for an Eagle truck intake [2009+] to better match up with the 6.1L port size.
2020 RAM 1500
Re: can 5.7 and 6.1 front acc. locations be changed on all hemis [Re: Mopar Ron] #2148110
09/05/16 04:58 PM
09/05/16 04:58 PM
Stinnett, Tx
rumblebee4232 Offline
Stinnett, Tx
And a different intake the 6.1 throttlebody wants the same space taken up by the Alternator and A/C compressor.. Also with the truck front cover you need the truck harmonic balancer as everything sticks out further..
Re: can 5.7 and 6.1 front acc. locations be changed on all hemis [Re: Mopar Ron] #2148115
09/05/16 05:02 PM
09/05/16 05:02 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I prefer the "make the car stuff work" method. Truck intakes are very unattractive anyway. The car acc setup is CLEAN.
Mopar to the bone!!!
Re: can 5.7 and 6.1 front acc. locations be changed on all hemis [Re: rumblebee4232] #2148117
09/05/16 05:02 PM
09/05/16 05:02 PM
runaway frown panic
Oh well I'll have to see how much room I have when I get a engine and see how it fits..
Thanks guys!!!!! thumbs up
Re: can 5.7 and 6.1 front acc. locations be changed on all hemis [Re: Mopar Ron] #2149451
09/07/16 10:46 AM
09/07/16 10:46 AM
gregsdart Offline
gregsdart  Offline
Forabodys only early a section search Tincup s thread he did a great writeup on a car 6.1 to early a and how to clearance for car alt locations etc
Re: can 5.7 and 6.1 front acc. locations be changed on all hemis [Re: GoodysGotaCuda] #2155484
09/16/16 01:15 AM
09/16/16 01:15 AM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
Goody, pm me if you want to get rid of that truck cover and accessories
69.5 A12 Bee, first purchased in 1976, car 169 on registry 69 Coronet R/T 440/4 spd 69 Coronet 500 Conv H code 383 4bbl/auto 37 Plymouth PU Find your spot on earth and ride it.
