can 5.7 and 6.1 front acc. locations be changed on all hemis
#2148043
09/05/16 03:33 PM
09/05/16 03:33 PM
Posts: 7,992 Escondido, CA. Ron Podsiadly,...
Mopar Ron
I am looking towards a future project . installing a 5.7-6.1 into a street rod and wondered if the front accessory brackets are interchangeable between all the engines. I would like to put the air and alt up high on the engine as to avoid clearance problems with the frame and steering shaft
here are a few pics of different configurations
I would think that are all compatible but you never know...
more like these top 2. things are pretty tight to the engine
the bottom picture looks like I might have clearance issues with hood side panels or frame...
Re: can 5.7 and 6.1 front acc. locations be changed on all hemis
[Re: GoodysGotaCuda]
#2148100
09/05/16 04:52 PM
09/05/16 04:52 PM
Mopar Ron
Timing covers are interchangeable but car cover accessories are -not- compatible with truck cover accessories. well that sucks. so if I buy a 6.1 from a car and want to move the alt and air up(if they interfere with the frame) I will need to get a truck timing cover and air unit and a different alt?
[Re: Mopar Ron]
#2148106
09/05/16 04:57 PM
09/05/16 04:57 PM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Timing covers are interchangeable but car cover accessories are -not- compatible with truck cover accessories. well that sucks. so if I buy a 6.1 from a car and want to move the alt and air up(if they interfere with the frame) I will need to get a truck timing cover and air unit and a different alt? Yessir, that's correct. I bought a truck motor and wanted a car cover, been there, done that. Also, the truck timing cover will likely not allow for a car [front] throttle body location, you may be limited to the truck [top] throttle body location which may or may not be what you're looking for. For what it's worth, I have a truck timing cover, non-eagle 5.7L truck intake manifold and a truck a/c compressor I will not be using. The intake port size will be smaller on the 5.7L intake when compared to the 6.1L head, you would likely want to hunt for an Eagle truck intake [2009+] to better match up with the 6.1L port size.
[Re: Mopar Ron]
#2148110
09/05/16 04:58 PM
09/05/16 04:58 PM
Posts: 198 Stinnett, Tx
rumblebee4232
Stinnett, Tx
Timing covers are interchangeable but car cover accessories are -not- compatible with truck cover accessories. well that sucks. so if I buy a 6.1 from a car and want to move the alt and air up(if they interfere with the frame) I will need to get a truck timing cover and air unit and a different alt? And a different intake the 6.1 throttlebody wants the same space taken up by the Alternator and A/C compressor.. Also with the truck front cover you need the truck harmonic balancer as everything sticks out further..
[Re: Mopar Ron]
#2148115
09/05/16 05:02 PM
09/05/16 05:02 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
I prefer the "make the car stuff work" method. Truck intakes are very unattractive anyway. The car acc setup is CLEAN.
Mopar to the bone!!!
[Re: rumblebee4232]
#2148117
09/05/16 05:02 PM
09/05/16 05:02 PM
Mopar Ron
Timing covers are interchangeable but car cover accessories are -not- compatible with truck cover accessories. well that sucks. so if I buy a 6.1 from a car and want to move the alt and air up(if they interfere with the frame) I will need to get a truck timing cover and air unit and a different alt? And a different intake the 6.1 throttlebody wants the same space taken up by the Alternator and A/C compressor.. Oh well I'll have to see how much room I have when I get a engine and see how it fits.. Thanks guys!!!!!
[Re: Mopar Ron]
#2149451
09/07/16 10:46 AM
09/07/16 10:46 AM
Posts: 10,016 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Forabodys only early a section search Tincup s thread he did a great writeup on a car 6.1 to early a and how to clearance for car alt locations etc
#2155484
09/16/16 01:15 AM
09/16/16 01:15 AM
Posts: 18,575 Dreaming of the 808
AZ_A12_BEE
Dreaming of the 808
Timing covers are interchangeable but car cover accessories are -not- compatible with truck cover accessories. well that sucks. so if I buy a 6.1 from a car and want to move the alt and air up(if they interfere with the frame) I will need to get a truck timing cover and air unit and a different alt? Yessir, that's correct. I bought a truck motor and wanted a car cover, been there, done that. Also, the truck timing cover will likely not allow for a car [front] throttle body location, you may be limited to the truck [top] throttle body location which may or may not be what you're looking for. For what it's worth, I have a truck timing cover, non-eagle 5.7L truck intake manifold and a truck a/c compressor I will not be using. The intake port size will be smaller on the 5.7L intake when compared to the 6.1L head, you would likely want to hunt for an Eagle truck intake [2009+] to better match up with the 6.1L port size. Goody, pm me if you want to get rid of that truck cover and accessories
69.5 A12 Bee, first purchased in 1976, car 169 on registry
69 Coronet R/T 440/4 spd
69 Coronet 500 Conv H code 383 4bbl/auto
37 Plymouth PU
Find your spot on earth and ride it.
