Where to get tan Dist cap and rotor for 340 electronic ign #2147958
09/05/16 01:27 PM
09/05/16 01:27 PM
Motown, Mi
P
PAULS_340 Offline OP
P
Motown, Mi
I need a new cap n rotor for my 340 with electronic ignition. Ebag and Rockauto don't have them....who does? thanks. Rotor #3874401
Still looking for LM29H1B415501, '71 Demon 340
Re: Where to get tan Dist cap and rotor for 340 electronic ign [Re: PAULS_340] #2147964
09/05/16 01:31 PM
09/05/16 01:31 PM
"Joesixpack" a member here
Re: Where to get tan Dist cap and rotor for 340 electronic ign [Re: PAULS_340] #2147965
09/05/16 01:32 PM
09/05/16 01:32 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Don't be the exception.
Re: Where to get tan Dist cap and rotor for 340 electronic ign [Re: PAULS_340] #2147970
09/05/16 01:36 PM
09/05/16 01:36 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
https://board.moparts.org/ubbthreads/ubbt...tml#Post2127298
I was wondering what an NOS set was worth.. work laugh
Re: Where to get tan Dist cap and rotor for 340 electronic ign [Re: Supercuda] #2148175
09/05/16 06:51 PM
09/05/16 06:51 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
what he said. good solid ones with brass contacts!
Re: Where to get tan Dist cap and rotor for 340 electronic ign [Re: mikemee1331] #2148415
09/05/16 11:46 PM
09/05/16 11:46 PM
Motown, Mi
P
P
Motown, Mi
The Summit one has that black, non-oem look thing on it.
Re: Where to get tan Dist cap and rotor for 340 electronic ign [Re: PAULS_340] #2148418
09/05/16 11:59 PM
09/05/16 11:59 PM
WA
tman Online content
tman  Online Content
WA
Hard to find one w/o the vent nowadays.
Re: Where to get tan Dist cap and rotor for 340 electronic ign [Re: PAULS_340] #2148436
09/06/16 12:22 AM
09/06/16 12:22 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
You asked for a tan cap.
If you want an original looking one then you are going to pay crazy prices.
Re: Where to get tan Dist cap and rotor for 340 electronic ign [Re: Supercuda] #2148660
09/06/16 10:54 AM
09/06/16 10:54 AM
Motown, Mi
P
P
Motown, Mi
Maybe I should just keep the tan one I have and sand/cleanup the contacts and get a new rotor...
Re: Where to get tan Dist cap and rotor for 340 electronic ign [Re: PAULS_340] #2148696
09/06/16 12:05 PM
09/06/16 12:05 PM
NAPA has a rotor with a .060" longer blade, a MO3000 for $8.xx. I would want a cap with brass contacts and ribs underneath & I would check rotor phasing/reduce lower end axial play to .005" and check tang/intergear notch rotational slop & reduce as needed to near zero
Re: Where to get tan Dist cap and rotor for 340 electronic ign [Re: RapidRobert] #2149448
09/07/16 10:37 AM
09/07/16 10:37 AM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
I sent PM i have two tan caps left with rotors for electronic ignition
they have aluminum contacts no epa vents, older style with ribs
Re: Where to get tan Dist cap and rotor for 340 electronic ign [Re: Joesixpack] #2149506
09/07/16 11:59 AM
09/07/16 11:59 AM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
HD BAKELITE, RIBBED, EXACT DUPLICATE OF 2444507 MOPAR CAP
Re: Where to get tan Dist cap and rotor for 340 electronic ign [Re: Joesixpack] #2149513
09/07/16 12:08 PM
09/07/16 12:08 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
second brand of same cap
