Where to get tan Dist cap and rotor for 340 electronic ign
#2147958
09/05/16 01:27 PM
09/05/16 01:27 PM
Posts: 1,043 Motown, Mi
PAULS_340
Motown, Mi
I need a new cap n rotor for my 340 with electronic ignition. Ebag and Rockauto don't have them....who does? thanks. Rotor #3874401
Still looking for LM29H1B415501, '71 Demon 340
Re: Where to get tan Dist cap and rotor for 340 electronic ign
[Re: PAULS_340]
#2147964
09/05/16 01:31 PM
09/05/16 01:31 PM
RapidRobert
"Joesixpack" a member here
[Re: mikemee1331]
#2148415
09/05/16 11:46 PM
09/05/16 11:46 PM
PAULS_340
Motown, Mi
The Summit one has that black, non-oem look thing on it.
[Re: PAULS_340]
#2148436
09/06/16 12:22 AM
09/06/16 12:22 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
The Summit one has that black, non-oem look thing on it. You asked for a tan cap. If you want an original looking one then you are going to pay crazy prices.
[Re: Supercuda]
#2148660
09/06/16 10:54 AM
09/06/16 10:54 AM
PAULS_340
Motown, Mi
Maybe I should just keep the tan one I have and sand/cleanup the contacts and get a new rotor...
[Re: PAULS_340]
#2148696
09/06/16 12:05 PM
09/06/16 12:05 PM
RapidRobert
NAPA has a rotor with a .060" longer blade, a MO3000 for $8.xx. I would want a cap with brass contacts and ribs underneath & I would check rotor phasing/reduce lower end axial play to .005" and check tang/intergear notch rotational slop & reduce as needed to near zero
