Front Motor Plate Question....Pics please #214680
02/05/09 10:52 AM
02/05/09 10:52 AM
Ohio
Duster_Dude Offline OP
Ohio
Ok motor plate guy's here's one for you....
I'm about to install a front motor plate & mounts in my '72 Duster. I'll be using a Mancini B/RB Billet front motor plate, and for mounts I plan on using 2" tall angle iron brackets mounted atop each frame rail on the front side of the plate.
One potential problem I see is clearance of the engine plate over top of the mounts when removing or installing the engine with the trans attached.
Not that I'll be doing that often, just thinking ahead.
As much as I'd like to weld them in, I've considered bolting them down to the frame rails for ease of taking the engine in and out.
The question I have is have any of you done this and how does it hold up?
Any unforseen problems here?
Below is a couple pics of what I've got (which sometimes ain't much!).
Please post any pics you have of your motor plates and mounts, I'd really like to see some.
Any help is greatly appreciated.
Thanks in advance!
Re: Front Motor Plate Question....Pics please [Re: Duster_Dude] #214681
02/05/09 11:23 AM
02/05/09 11:23 AM
Arizona
PolyDart Offline
PolyDart  Offline
Arizona
I set mine up in a double shear arrangement. The one in back is welded and bolted, the one in front is just bolted so the engine can be easily removed.
Re: Front Motor Plate Question....Pics please [Re: PolyDart] #214682
02/05/09 11:31 AM
02/05/09 11:31 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Problem.... take the front bracket off, other wise
you have to go up and over it to drop in the engine.
I know you have it bolted, just weld the rear one
in place and you wont need the front one and you wont
have bolts coming loose
Re: Front Motor Plate Question....Pics please [Re: PolyDart] #214683
02/05/09 11:33 AM
02/05/09 11:33 AM
S.E. South Dakota !
bigdad Online content
Still Posting A Lot
bigdad  Online Content
Still Posting A Lot
S.E. South Dakota !
Mine tie in the upper shock mounts and mount the plate off them
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: Front Motor Plate Question....Pics please [Re: bigdad] #214684
02/05/09 11:50 AM
02/05/09 11:50 AM
LOWELL IN
Q
QWK_ENUF Offline
QWK_ENUF  Offline
Q
LOWELL IN
ok
WAXER
Re: Front Motor Plate Question....Pics please [Re: Duster_Dude] #214685
02/05/09 12:05 PM
02/05/09 12:05 PM
AndyF Offline
AndyF  Offline
Looks good so far but you don't need the front brackets. There really isn't very much force on those brackets. The weight of the engine keeps it in place for the most part. Even with 600 ft-lbs of torque the bolts only have to resist about 150 lbs of shear force each on the driver's side. That is nothing for a bolt that size to handle.
Re: Front Motor Plate Question....Pics please [Re: PolyDart] #214686
02/05/09 12:10 PM
02/05/09 12:10 PM
MR_P_BODY Offline
MR_P_BODY  Offline
One thing, I would keep the 2 mounting bolts in the
plate like you have, this does help in frame flex
where a single bolt can let it pivot on the bolt, sure
it would be binding but it still can flex
EDIT
I would also add engine limiters to take the torque
of the launch
Re: Front Motor Plate Question....Pics please [Re: MR_P_BODY] #214687
02/05/09 12:20 PM
02/05/09 12:20 PM
Las Vegas
afxcoronet Offline
afxcoronet  Offline
Las Vegas
Here's mine...
Taking over the World one win light at a time.
Re: Front Motor Plate Question....Pics please [Re: Duster_Dude] #214688
02/05/09 12:25 PM
02/05/09 12:25 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I welded mine behind the plate that way the motor slides out easier and when installing the motor, it slides right in and butts up againtsed the brackets.
Re: Front Motor Plate Question....Pics please [Re: Thumperdart] #214689
02/05/09 06:39 PM
02/05/09 06:39 PM
Ohio
Ohio
ab7fh, like those shiny brackets.
That seems to be the most sensible way to do it with my set up.
Thanks for the input fella's, some great work there!
Keep those pics comin'!
Re: Front Motor Plate Question....Pics please [Re: AndyF] #214690
02/05/09 06:56 PM
02/05/09 06:56 PM
Arizona
PolyDart Offline
PolyDart  Offline
Arizona
I like the double shear setup. It may be over kill, but that's ok with me. I'm not running in a class that needs to worry about every last ounce of weight.
To the poster who said the front bracket is in the way. The front bracket is removable. No problem pulling the motor forward.
Re: Front Motor Plate Question....Pics please [Re: Duster_Dude] #214691
02/05/09 07:28 PM
02/05/09 07:28 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
heres mine :
1.39 9.85 - 137 mph
Re: Front Motor Plate Question....Pics please [Re: Ari440] #214692
02/05/09 09:23 PM
02/05/09 09:23 PM
Wichita Kansas
B Dartman Offline
B Dartman  Offline
Wichita Kansas
I agree with Mr_P_Body See my signature link photos... I welded the bracket in front and is a bit of a hassle going up and over as it's a pretty snug fit. Would have been better with bracket behind the plate..
B Dartman's 71 Dart Swinger in Mopar Muscle (Sold Dec 2021): https://www.hotrod.com/articles/1971-dodge-dart-destiny-determination/
B Dartman's 71 Dart Swinger in Dodge Garage (Sold Dec 2021): https://www.dodgegarage.com/news/article/showcase/2019/04/destiny-determination.html
B Dartman's 71 Dart Swinger early build pictures (Sold Dec 2021): https://s165.photobucket.com/user/Billswild440dart/library/
Re: Front Motor Plate Question....Pics please [Re: B Dartman] #214693
02/05/09 09:29 PM
02/05/09 09:29 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
if you weld the plate in the front its a pain to do
but if you pass a long bolt througth the frame rail its only one bolt per side to do
I did mine so you use the whole frame rail to hold the moter in place, then just welding the bracket on a thin metal rail on top
1.39 9.85 - 137 mph
Re: Front Motor Plate Question....Pics please [Re: MR_P_BODY] #214694
02/05/09 10:09 PM
02/05/09 10:09 PM
Maryland
Dads426 Offline
Dads426  Offline
Maryland
I would also add engine limiters to take the torque of the launch
What do your limiters look like? Are they off the factory ears on the block? I thought the motor plate would limit engine movement without the need for limiters.
2012 422 Allstars NSS Champion
2013 422 Allstars NSS Champion
2014 422 Allstars NSS Champion
Re: Front Motor Plate Question....Pics please [Re: Dads426] #214695
02/05/09 10:31 PM
02/05/09 10:31 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: Front Motor Plate Question....Pics please [Re: bigtimeauto] #214696
02/05/09 11:18 PM
02/05/09 11:18 PM
Riverside, Ca
G_bob Offline
G_bob  Offline
Riverside, Ca
As long as I'm re-doing the motor, I figured I'd fix the motor plate setup and down bars as well.
Here is how it was set up before.
Can't see it well in the pic, but the motorplate mounted to tabs on the downbars from the backside, so there's no way to pull the motor with the plate attached.
Major PITA.
Now don't laugh, cause it looks bad now, but the block is just an old junker to use for positioning, the real one is at the machine shop.
Anyway, the plate is replaced by elephant ears (although I'm seriously considering an AR Engineering plate instead.
The ears are bolted from the frontside to tabs welded to the frame rails.
Also re-did the down bars to lay them over next to the inner fenders and they are stitched to the shock towers.
It's still ugly, but as soon as I pull the old block out I'll be re-painting the engine bay, re-doing the wiring and re-plumbing the brake, trans and fuel lines.
Re: Front Motor Plate Question....Pics please [Re: G_bob] #214697
02/06/09 12:54 AM
02/06/09 12:54 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
The elephant ear will work for awhile , they have a problem with the water pump gaskets leaking from engine torqueing back and forth.
Re: Front Motor Plate Question....Pics please [Re: Dads426] #214698
02/06/09 01:15 AM
02/06/09 01:15 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I dont think I have any pics but yes I use the motor
mount ears to a tab welded to the chassis/frame. You
could incorporate the motor plate tab and the limiter
tab all in one. A flat plate isnt the best thing to
control fore/aft movement, specially if you launch hard
Re: Front Motor Plate Question....Pics please [Re: G_bob] #214699
02/06/09 10:32 AM
02/06/09 10:32 AM
Ohio
Ohio
Major PITA.
It's gotta be ugly before its purdy.....
I like the idea with the down bars, I thought about making some sort of bracket to connect the bars to the shock towers....but with fenderwell headers, I wanted to get the bars away from everything.
