Help Me Pick My Cam on My New Bullett
#214584
02/05/09 06:52 AM
02/05/09 06:52 AM
Posts: 6,295 U.S.
moparniac
U.S.
You guys keep busting my chops about my baby solid roller so spec me one.... I currently run a comp cams solid roller 248/254 @ .050 and .640 net lift with the harland 1.7's... the gentlemen who help me build my motor originally has since passed away and never got to see the car run and I belive all his measurements are for my mill but cannot confirm nor deny it yet.... I would like to stay in abou the same lift range (.650) with my 1.7' new heads coming real soon MCH CNC'd Indy EZ's 2.19*1.81 and compression is 11.1 with a felpro 1009... I am sure of these specs piston is in the hole .013 they are J&E notched pistons.... how much lift I can go is undertermined yet... but i would like to stay close to my lift now anyway.. some i have found ??? 260/266 with .588/.597 lift .398 lobe lift Bullet Cams R297/385 297 262 170 .385 .013 CRA R299/385 299 264 171 .385 .013 CRA R301/385 301 266 173 .385 .013 CRS
Mopar Performance
Re: Help Me Pick My Cam on My New Bullett
[Re: Quicktree]
#214586
02/05/09 07:50 AM
02/05/09 07:50 AM
Posts: 2,528 Mansfield, Tx
Jacob Pitt
Mansfield, Tx
I think the best way is getting someone that knows about cams and how they work way better than the average guy is the best way. I had Straightline spec out my cam for my big block, and RyanJ work with Bullet for the cam for the small block. Call a cam company talk to their tech guy and have them spec you out a cam. You don't have to buy it, but it will give you the best idea.
2013 NHRA D4 Stock Champ #4 in the World IHRA Stock 2x IHRA Div.4 Stock Champ 14x Track Champ All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
[Re: Quicktree]
#214587
02/05/09 08:06 AM
02/05/09 08:06 AM
Posts: 13,365 Marion, South Carolina [><]
an8sec70cuda
get ahold of Dwayne (fast68plymouth) he can spec you out a cam that will work.
Call Dwayne and get it right the first time. CHIP
[Re: an8sec70cuda]
#214588
02/05/09 12:50 PM
02/05/09 12:50 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
I'm sorry, I'm not familiar enough with what you're running.. Can you post the rest of the combo?
