1.33 60 foot on the back tires... #2143543
08/30/16 12:27 AM
08/30/16 12:27 AM
Saskatchewan, Canada
cudabin Offline OP
cudabin  Offline OP
Playing around at the airport drags. Traction was good...
https://www.youtube.com/watch?v=XnK0qyXOjlE&feature=youtu.be
100 foot wheelie and a 1.33 60 foot with the back tires. Best 60 foot with the front tires on the ground that day was a 1.25, sitting down just before the 60 foot lights.
cheers,
Arnie
67 Cuda 8.48@ 158.7 mph 1.18 60' 2,600 DA(so far...) 70 Super Bee 440 Six Pack 4-speed. 13.2 @ 104 Stock exhaust/Street tires.
Re: 1.33 60 foot on the back tires... [Re: cudabin] #2143550
08/30/16 12:39 AM
08/30/16 12:39 AM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
Nice job you're going to have to get yourself a cowboy hat
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: 1.33 60 foot on the back tires... [Re: cudabin] #2143583
08/30/16 01:17 AM
08/30/16 01:17 AM
Alberta
Wookie316 Offline
Wookie316  Offline
Alberta
Nice. Seen you run there. I was running Barney the purple 71 Superbee. Very nice ride. My bud with his 69 Camaro had some bad luck. Did you see the video?
Whole front end flew off.
1971 Plum Crazy Super Bee. 572 World Aluminum block with a Cope 727 & Dana 4.10 out back. 9.88 @ 138 with a 1.35 60 NA. Dialed back to 10.0’s. 4000 lbs with me in it.
Re: 1.33 60 foot on the back tires... [Re: cudabin] #2143682
08/30/16 09:41 AM
08/30/16 09:41 AM
gregsdart Offline
gregsdart  Offline
Arnie, great pass!
Re: 1.33 60 foot on the back tires... [Re: cudabin] #2143821
08/30/16 01:03 PM
08/30/16 01:03 PM
Alexandria, LA
Blucuda413 Offline
Blucuda413  Offline
Alexandria, LA
That is a nice looking car, and hauls azz too!!!!!
Re: 1.33 60 foot on the back tires... [Re: cudabin] #2143855
08/30/16 01:51 PM
08/30/16 01:51 PM
an8sec70cuda Offline
Good run, looks like fun!!!
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 1.33 60 foot on the back tires... [Re: cudabin] #2143884
08/30/16 02:32 PM
08/30/16 02:32 PM
st.louis,mo.
dart games Offline
dart games  Offline
st.louis,mo.
bad ass cuda
Re: 1.33 60 foot on the back tires... [Re: cudabin] #2145160
09/01/16 02:26 AM
09/01/16 02:26 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Looking good. Looks like maybe you tightened stuff up a bit but at any rate good hit for sure..
Re: 1.33 60 foot on the back tires... [Re: cudabin] #2145341
09/01/16 01:09 PM
09/01/16 01:09 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
That had to be a fun ride!
Re: 1.33 60 foot on the back tires... [Re: Al_Alguire] #2146133
09/02/16 01:47 PM
09/02/16 01:47 PM
cudabin Offline OP
cudabin  Offline OP
Hey Al,
So if I want to improve the 60 foot time further, should I just tighten the front end to the point it starts to spin the tires a bit??
I had 10psi in the tires, and rear end is fairly stiff already...
I did have 4 degrees launch retard in it for .65 seconds, so I will try without next time.
Going out tomorrow to an 1/8 mile track so I will play around with the front shocks and see if I can get the front tires back on the ground before 60 foot lights this time...
Re: 1.33 60 foot on the back tires... [Re: cudabin] #2146263
09/02/16 05:08 PM
09/02/16 05:08 PM
Medina, OH
dart440_72 Offline
dart440_72  Offline
Medina, OH
Looks great!!!!
72 Dart 500" low deck Indy SR heads. 10.40 @129 best so far
Re: 1.33 60 foot on the back tires... [Re: cudabin] #2146792
09/03/16 02:03 PM
09/03/16 02:03 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Yes I would tighten up the front end next. Also you can run less pressure in the rear tires as well that will build wheelspeed as well. As for the timing yeah the idea would be to not take any out. But the chassis will need to work to accomplish that as well. Keep chipping away at it. Looks great.
