Page 5 of 8 1 2 3 4 5 6 7 8
Re: Mikey`s Mopar 470 on the pump.............GUESSES? [Re: BobR] #2142912
08/29/16 02:37 AM
08/29/16 02:37 AM
fresno ca
mikeysmopars Offline
fresno ca
OK a few test results from this weekend. First the place was packed, very surprised the pits so full, unloaded went to tech and found out my belts were a month out of date rolleyes. Got that fixed & went to get the first run with front shocks set about neutral.didnt set the twostep so it didn't leave real hard but ran a 9.95 with 1.46 60 ft @ 135. Only got two runs Saturday so I adjusted front shocks a little looser.checked plugs was a little lean looking changed jets from 92 to 96 made second run around 1:30 and was hot, air was 2700 second run it went 9.89@135 and the 60 came up to 1.42 day was over for us so I changes high speed bleeds,adjusted shocks again and changed chip in launch from 3000 to 3400 and went to Sunday eliminations.launched and watched the other guy and never noticed I went red so I was way out on him and lifted.got my time slip and went 9.89 @122
With 1.38 60 but felt like its leaving soft. Not a bad outing considering that's the first time I've been in my car in almost a year and everything is new.there is a lot left in it but only three runs so I need a good TNT to get it sorted. That last run it went 6.22 in the eighth so I'm gaining. Going back the 16 th next month so I'll hopefully have a few more runs.
IMG_20160827_104025813-480x640.jpgIMG_20160827_131127131-480x640.jpgIMG_20160828_092551412-480x640.jpg
Founder and CEO of the Central Valley Mopar Drag Pack
Re: Mikey`s Mopar 470 on the pump.............GUESSES? [Re: mikeysmopars] #2143120
08/29/16 01:21 PM
08/29/16 01:21 PM
State of confusion
Thumperdart Offline OP
State of confusion
Just shake down runs and you`ve change just about everything on your car so back to square one. In the vid I saw it wasn't transferring weight and spun a bit so test, test and test some more Mike and you`ll get it.............. thumbs Lookin at that slip again, I`d bet you were on a 9.60-70 pass only going 122............
Re: Mikey`s Mopar 470 on the pump.............GUESSES? [Re: Thumperdart] #2143292
08/29/16 07:28 PM
08/29/16 07:28 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
Good job Mike I'm glad it came together for you.. and already is faster then it was before.. these bricks that we drive are hard to make go fast.. trust me I know . I'm happy if it goes home in one piece.lol keep picking away at it..
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Mikey`s Mopar 470 on the pump.............GUESSES? [Re: WHITEDART] #2143584
08/30/16 01:20 AM
08/30/16 01:20 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Well for the HP the runs are slower then some/most of the predictions. BUT, these are some of your first shakedown runs, with the New Combo and we all know that they can be far off from a dialed in combo.
Congrats on the new bests. A lot of your lost ET is at the start as you have already noticed. Also others have stated that track doesn't have the best air this time of year. Congrats on getting it out. Thanks for sharing the first outings results. Looking forward to forward tunings.
Re: Mikey`s Mopar 470 on the pump.............GUESSES? [Re: Sport440] #2143601
08/30/16 01:56 AM
08/30/16 01:56 AM
fresno ca
fresno ca
Thanks everyone, going back in a couple weeks, first time with coil over front end and double adjustable shocks. Didn't get all I wanted but happy I had no issues with all I changed and did get a personal best. Hopefully I'll get more than three runs.
Re: Mikey`s Mopar 470 on the pump.............GUESSES? [Re: mikeysmopars] #2143687
08/30/16 09:52 AM
08/30/16 09:52 AM
tboomer Online work
tboomer  Online Work
I have been following this thread and you are right where I want to be! Nice job and I know you have more in it! boogie
Re: Mikey`s Mopar 470 on the pump.............GUESSES? [Re: Thumperdart] #2143763
08/30/16 11:46 AM
08/30/16 11:46 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
always nice to get through the first "new" weekend with everything in tact. now it's just time for seat time and getting comfortable with everything. See ya in a month!
Re: Mikey`s Mopar 470 on the pump.............GUESSES? [Re: Thumperdart] #2143823
08/30/16 01:04 PM
08/30/16 01:04 PM
Sunnyvale, CA
Jeepmon Offline
Jeepmon  Offline
Sunnyvale, CA
Very nice Mike... Thanks for keeping all of us updated..
Re: Mikey`s Mopar 470 on the pump.............GUESSES? [Re: Al_Alguire] #2143889
08/30/16 02:36 PM
08/30/16 02:36 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Originally Posted By Al_Alguire
Not trying to poopoo numbers here. A question was asked and I gave my answer. Generally depending on the dyno and it water tower capacity or where the water comes from they try not to get them to hot. It may take too long to cool down between runs. The dyno this engine was done on from my experience is not a happy dyno by any means. Generally you can out the ole moroso slide rule to the numbers and have a good idea what an engine off of the Pettis dyno will run in the car. Once the car combination is optimized.
Yes it is true you can make a dyno pretty much spit out inflated corrected numbers. That's great for the dyno crowd. Thus why I always say I want to see a quantifiable result from any dyno when it comes to actual ET's. It is pretty standard practice industry wide to make the last pull with things cool off as much as reasonably possible. It does not mena you get 40 more HP buy any means. You will generally see a gain but it aint gonna move that much. Oil temps and water temps are always monitored, or at least shold beon the Dyno.
My engine that was just on the dyno it was hard to get water temps up very high. The reason being the facility uses a city water connection on the dyno. So they have and endless stream of cold wate at their disposal. Just a matter of running the water pump for a few minutes to get the engine temps down. The dyno we used is notoriously stingy for the numbers it kicks out. It is a new DTS/Superflow unit with a state of the art no expense spared dyno room. It has been pretty consistently down on power from where we used to use. And that dyno was considered stingy by some and honest by many. Numbers usually went dead on to the moroso wheel from the old one.
Interesting what you said, I had a 499 that Kenny L built when he was with McCandless. 15.19 compression Indy head, long story short engine ran hot then finally got temp down to leave at 160 degrees, lost a tenth and one haft. Called Kenny, was told that engine had to leave at 200 degrees to build heat in the heads?? Did that and ran the good number again. A little confusing when some say run it cold and some say run it hot??
Re: Mikey`s Mopar 470 on the pump.............GUESSES? [Re: cudaman1969] #2143913
08/30/16 02:50 PM
08/30/16 02:50 PM
Cab_Burge Online work
Cab_Burge  Online Work
Mopars are not Chebbys or Furds shruggy
Many misleading myths on what works best on our cars shruggy
Re: Mikey`s Mopar 470 on the pump.............GUESSES? [Re: Thumperdart] #2144057
08/30/16 07:07 PM
08/30/16 07:07 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
Nice first outing, i'm suprised you didn't run it all out after you went red though.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: Mikey`s Mopar 470 on the pump.............GUESSES? [Re: deaks] #2144076
08/30/16 07:35 PM
08/30/16 07:35 PM
fresno ca
fresno ca
Honestly I thought I was still in it!....Never occurred to me to look up at the lights, First time in a year in my car so still getting used to it. The whole time I was getting to the ticket booth I assumed I Broke Out!! laugh2
Re: Mikey`s Mopar 470 on the pump.............GUESSES? [Re: Cab_Burge] #2144195
08/30/16 10:45 PM
08/30/16 10:45 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Yes, many misleading myths,
Re: Mikey`s Mopar 470 on the pump.............GUESSES? [Re: Thumperdart] #2144395
08/31/16 06:28 AM
08/31/16 06:28 AM
Arizona
Chris'sBarracuda Offline
Arizona
Look again.. More like a 9.82.. work
Chris.
Re: Mikey`s Mopar 470 on the pump.............GUESSES? [Re: Chris'sBarracuda] #2144514
08/31/16 12:18 PM
08/31/16 12:18 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
Chris.
I agree but i'm sure in cooler weather and a bit more tuning a 70 is achievable.
Mick
best 60ft 1.36
Re: Mikey`s Mopar 470 on the pump.............GUESSES? [Re: Chris'sBarracuda] #2144535
08/31/16 01:04 PM
08/31/16 01:04 PM
State of confusion
State of confusion
Chris.
YOU look again...........he went 9.89 at 135+ then 9.89 at 122........what don`t you get............. realcrazy
Re: Mikey`s Mopar 470 on the pump.............GUESSES? [Re: Thumperdart] #2144537
08/31/16 01:12 PM
08/31/16 01:12 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Chris.
Calculate it off the 1000 foot data.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Mikey`s Mopar 470 on the pump.............GUESSES? [Re: pittsburghracer] #2144539
08/31/16 01:18 PM
08/31/16 01:18 PM
State of confusion
State of confusion
No clue on that but I scrubbed 10+ mph and lost a chunk of et but don`t remember exactly how much. Plus as I told Mikey and was correct in that the dyno tune would be off and it is. Jason had the mixture screws 3/4 out and it ran bad till he brought em out to 1 1/2 where I had em and it wants more jet as expected also. Dynos are a tool and a way to see if our junk leaks and set BASIC starting points that`s it imo...........That car will go easy 9.60`s or better.............
Re: Mikey`s Mopar 470 on the pump.............GUESSES? [Re: Thumperdart] #2144569
08/31/16 02:18 PM
08/31/16 02:18 PM
Renton Washington
Triple Threat Offline
Renton Washington
Thumper,
If we look at the 1000 foot numbers on his full run where he didn't lift it took him 1.649 seconds to go from 1000 to 1320 under power.
If we take the 1000 foot time on the run where he lifted and add the "known" split time from 1000-1320 the car was going to run about 9.82 as indicated above.
Full pass
9.897 to 1320
8.248 to 1000
9.897 - 8.248 = 1.649 seconds
Lifted pass it was 8.171 to 1000
8.171 + 1.649 = 9.820
No one is doubting the car has the ability to run in the 60's, but it wasn't going to do it on that run.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Mikey`s Mopar 470 on the pump.............GUESSES? [Re: Triple Threat] #2144615
08/31/16 03:27 PM
08/31/16 03:27 PM
State of confusion
State of confusion
Cool...........I know the math is pretty close but scrubbing 13+ mph just doesn't calculate in my brain............
