E-body Carpet set difference between Challenger and Cuda #2144054
08/30/16 07:04 PM
08/30/16 07:04 PM
Wichita Kansas
6PacCuda Offline OP
6PacCuda  Offline OP
Wichita Kansas
I am working on a 74 Cuda and was given a new black carpet set. I was looking at the box and it says its for a Challenger. What is the difference between the two. Both cars are automatics. I know the Challenger has a longer wheel base, but I thought that would not matter since the carpet is two piece.
Re: E-body Carpet set difference between Challenger and Cuda [Re: 6PacCuda] #2144665
08/31/16 04:35 PM
08/31/16 04:35 PM
Ormond Beach, FL
71STROKERFISH Offline
Ormond Beach, FL
Good question....I'd ask Year One. Is it a console/auto/4-speed car?
-dc
SOUTHERNPLAINSMOPAARFEST.COM
2018 Jeep Trackhawk
1994 Jeep Grand Cherokee, 5.2 AWD-Daily grinder since 1997
1971 Barracuda, 414ci, 6bbl Fitech, 727
1970 Barracuda Convertible, 472 Ray Barton Hemi, 727
Re: E-body Carpet set difference between Challenger and Cuda [Re: 6PacCuda] #2144802
08/31/16 07:24 PM
08/31/16 07:24 PM
BDW Offline
BDW  Offline
I'd check RockAuto to see if the PNs are different
Re: E-body Carpet set difference between Challenger and Cuda [Re: 6PacCuda] #2145084
09/01/16 12:38 AM
09/01/16 12:38 AM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Only difference is the rear piece is longer for the Challenger. No problem using in a Cuda. Just trim it back if needed.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: E-body Carpet set difference between Challenger and Cuda [Re: moparmarks] #2145320
09/01/16 12:31 PM
09/01/16 12:31 PM
Wichita Kansas
6PacCuda Offline OP
6PacCuda  Offline OP
Wichita Kansas
I was hoping it was the back piece that was different. I called Legendary and all he could tell me was that there are different part #'s between a Cuda and Challenger. Looks like I will be good to go and I will just run the extra under the front piece if needed.
Re: E-body Carpet set difference between Challenger and Cuda [Re: 6PacCuda] #2145397
09/01/16 02:37 PM
09/01/16 02:37 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
You should be good to go if you trim the back piece
