Re: Anyone here install windshield ? [Re: toplescuda] #2142408
08/28/16 12:42 PM
08/28/16 12:42 PM
Western Colorado High Desert
moparmarks Online penguin-006
moparmarks  Online Penguin-006
I use 3/8" and the front and 5/16" on the rear.
On the spacers they are like 3/16x3/16x1. Don't know if anyone is making them.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: Anyone here install windshield ? [Re: toplescuda] #2142443
08/28/16 01:42 PM
08/28/16 01:42 PM
WI
W
wannadrag Offline
wannadrag  Offline
W
WI
Last stuff I bought the spacers came with it.
Re: Anyone here install windshield ? [Re: 71rm23] #2142462
08/28/16 02:05 PM
08/28/16 02:05 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
Originally Posted By 71rm23
Originally Posted By toplescuda
Orignal windshield. Yeah I don't remember if still have the Lil rubber wedges that windshield sets on or not......let just say I don't. Where can I come up with those at?
71 RR here. I don't have the rubber spacers (lost) and be interested on where to get them as well or ideas on what to use instead.
Also, on the butyl tape. Was there a 3/8" in the front and 5/16" for the rear?
Setting blocks should come with the butyl tape kit.. If not, an Auto Glass shop should have some no problem....
99% of the time 3/8 front, 5/16 rear....
Make sure you get some WS primer and apply it to the area of the glass and the pinchweld where the butyl tape kit sets.... VERY IMPORTANT....
Two people should be able to hold the glass by its edge with your fingers. One hand on the bottom and the other holding the side of WS. Communicate with each other to get an equal space on both sides, from each A pillar while setting the bottom.... It should set on the rubber/plastic setting blocks.. THEN together set the top down into the tape kit..... Apply light pressure to push the ws into the tape kit.. It wont smash it down flat, and its not supposed to , but it does need seal to the tape kit..
You can microwave the kit somewhat to soften it JUST A LITTLE.. I would try 30 seconds at a time until you soften it or just warm it a bit... It will help with the bond..
If its really hot out, disregard.....
You are dealing with a used WS... Getting it out is the hardest part... BUT there are LOTS of little tiny pits that will run ( glass will crack) so be carefull not to twist the WS or stress it while handling or installing...
Good luck
Re: Anyone here install windshield ? [Re: toplescuda] #2142642
08/28/16 07:21 PM
08/28/16 07:21 PM
poplar bluff mo.
toplescuda Offline OP
I Whine
I Whine
poplar bluff mo.
I don't have to use primer being I just had the car painted (with glass out)correct???
Car was blasted in window channels to bare metal before paint prep
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: Anyone here install windshield ? [Re: toplescuda] #2142666
08/28/16 08:00 PM
08/28/16 08:00 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
The windshield primer is a black liquid put on the body that the butyl sticks to.
You and your helper need to wash your hands and not have any oil or residue on them or the glass will leak where the fingerprints are.
Re: Anyone here install windshield ? [Re: toplescuda] #2142672
08/28/16 08:07 PM
08/28/16 08:07 PM
None
71rm23 Offline
71rm23  Offline
None
There must be a special kind of primer to use, correct? Type or brand? I'll be doing a install soon on my car is why I ask. Not to jump on OP topic here
Re: Anyone here install windshield ? [Re: toplescuda] #2142693
08/28/16 09:00 PM
08/28/16 09:00 PM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
So it has to have it even if surface is clean then. Guiess sell it at parts store also?
1971 charger
Re: Anyone here install windshield ? [Re: toplescuda] #2142735
08/28/16 09:56 PM
08/28/16 09:56 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
3M used to make the black GLASS PRIMER we used back in the day..
I have seen a clear type used but have never used it.....
YES a special primer for glass install... It has NOTHING to do with paint.... Really important to bond the tape kit to the painted metal pinchweld.....
Re: Anyone here install windshield ? [Re: moparmarks] #2142737
08/28/16 09:58 PM
08/28/16 09:58 PM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
Possible pic with tape measure?? Will be going into 71 charger if matters
If had some good pics I could prob by make some. Ya know the old saying. Pic worth thousand words lol
1971 charger
Re: Anyone here install windshield ? [Re: toplescuda] #2142902
08/29/16 02:03 AM
08/29/16 02:03 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Re: Anyone here install windshield ? [Re: kentj340] #2142909
08/29/16 02:31 AM
08/29/16 02:31 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
71 doesn't use a gasket.
Re: Anyone here install windshield ? [Re: toplescuda] #2142923
08/29/16 03:32 AM
08/29/16 03:32 AM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
Yep no gasket on 71 b body
1971 charger
Re: Anyone here install windshield ? [Re: toplescuda] #2143172
08/29/16 02:59 PM
08/29/16 02:59 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
Years ago I worked in a wrecking yard and we sold windshields. We had all the tools to take out the gasketed and glued-in windshield and we still broke half of them. Unless you are determined to have a "numbers matching" windshield to go with the spare tire that has "original air" in it, have a pro install new glass. It probably will look better and have a guarantee by the installer. JMHO
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: Anyone here install windshield ? [Re: wannadrag] #2146964
09/03/16 08:26 PM
09/03/16 08:26 PM
Missouri
MOBodyman Offline
MOBodyman  Offline
Missouri
The 3M kits I buy at the parts store have spacers included too. I think I still have a bunch of spares in a drawer at the shop.
Dallas
2012 Rallye Redline Challenger, 1st new car!
2010 Ram 1500 4wd HEMI-hauler
2014 Dodge Dart-gas saver
4 projects and a bunch of parts cars, losing interest since buying the Challenger lol
1969 Dodge Coronet 500-'gonna fix 'er up someday!'
Re: Anyone here install windshield ? [Re: toplescuda] #2147058
09/03/16 11:19 PM
09/03/16 11:19 PM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
I haven't had a chance to look at a kit yet. I need to check it out. Thank you
1971 charger
