2016 Challenger 5.7 engine noise #2127109
08/07/16 01:38 PM
08/07/16 01:38 PM
RI
cudascooter Offline OP
RI
I have a 2016 Challenger 5.7 shaker car that I bought new and only has 1500 miles on. I have been hearing a tick when I first start it and the other day after sitting for over a week it was really loud to the point I was getting ready to shut it down. However it went away after a few seconds. It is almost like a lifter(s)is bleeding down and pumping back up after start up. Oil level is where it should be.
Anyone else been experiencing this noise?
Re: 2016 Challenger 5.7 engine noise [Re: cudascooter] #2127138
08/07/16 02:18 PM
08/07/16 02:18 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
5.7,Hemi's are notorious for lifter ticks.
Re: 2016 Challenger 5.7 engine noise [Re: cudascooter] #2127457
08/07/16 10:23 PM
08/07/16 10:23 PM
Burlington, Ontario Canada
Dave_S Offline
Dave_S  Offline
After it sits for a week?
Don't worry about it!!
Dave Stillie
'73 Swinger
5.7 Hemi, 88mm turbo, powerglide, cal-tracs & 8 3/4
Mega-Squirt EFI
[email]8.93@149
[/email]
Re: 2016 Challenger 5.7 engine noise [Re: cudascooter] #2127480
08/07/16 10:52 PM
08/07/16 10:52 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Automatic car? My 16 Ram does same thing.
Mopar to the bone!!!
Re: 2016 Challenger 5.7 engine noise [Re: cudascooter] #2127922
08/08/16 02:59 PM
08/08/16 02:59 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
A lot...most...new hemis have a lifter tick when you first start them up. My 14 Ram does it from time to time. It stops after a second or two and runs fine. You can Google "Hemi tick" and find a lot of posts about it.
Re: 2016 Challenger 5.7 engine noise [Re: burdar] #2128040
08/08/16 06:05 PM
08/08/16 06:05 PM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
My Jeep with the 5.7 does the same thing, mostly on cold days during warm up.
Re: 2016 Challenger 5.7 engine noise [Re: cudascooter] #2128122
08/08/16 07:58 PM
08/08/16 07:58 PM
CJD AUTOMOTIVE Offline
Just my opinion, but I think it is because the lifter sits horizontal and allows the oil to drain out. Would love to hear from someone with an Accusump on their engine to see if pressurizing the system before starting made this go away. I've worked on them since they were first introduced, and they all have a slight tick. Also have customers with well over 400K on them with no issues, but still the start up tick. I have seen first hand (or actually heard) that anything but a Mopar filter increases the severity and length of time to pump up the lifters.
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
www.CJDAUTOMOTIVE.com
904-400-1802
"I own a Mopar. I already know it won't be in stock, won't ship tomorrow, and won't fit without modification"
Re: 2016 Challenger 5.7 engine noise [Re: cudascooter] #2128186
08/08/16 09:23 PM
08/08/16 09:23 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
My 6.1 in the Dart DOES NOT tick at start up. Always have used Wix 51515R filter which has anti drainback. After running it hard you can hear all the lifters at cruise a little.
Re: 2016 Challenger 5.7 engine noise [Re: cudascooter] #2128349
08/09/16 12:09 AM
08/09/16 12:09 AM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
I've heard a fix for the early 5.7's is installing a 6.1's entire valvetrain (cam, pushrods and springs)
Re: 2016 Challenger 5.7 engine noise [Re: cudascooter] #2128505
08/09/16 09:06 AM
08/09/16 09:06 AM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
2012 stick car, quiet as the grave on start up. 41k
Just lucky I guess
"I think its got a hemi"
Re: 2016 Challenger 5.7 engine noise [Re: gdonovan] #2128685
08/09/16 01:58 PM
08/09/16 01:58 PM
RI
RI
The dealer wanted to see the car so I brought it there last night. I haven't heard back yet...
Re: 2016 Challenger 5.7 engine noise [Re: cudascooter] #2129440
08/10/16 01:33 PM
08/10/16 01:33 PM
RI
RI
The dealership stated it didn't make the noise when they started it the following day. So I am starting to believe it is the characteristic of the Hemi 5.7. I will use "slick 50" to resolve the problem...only kidding...remember that stuff? I am going to try that Wix oil filter that prevents the oil from draining back. thanks and I will you know if that resolves the issue.
Still a great car and I enjoy it very much!
Re: 2016 Challenger 5.7 engine noise [Re: cudascooter] #2129500
08/10/16 02:36 PM
08/10/16 02:36 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
That filter will not fit your car fyi. Look on their website for one that does that has anti drainback.
Re: 2016 Challenger 5.7 engine noise [Re: 72Swinger] #2129566
08/10/16 03:43 PM
08/10/16 03:43 PM
RI
RI
okay thanks!
Re: 2016 Challenger 5.7 engine noise [Re: cudascooter] #2131304
08/12/16 05:48 PM
08/12/16 05:48 PM
Columbus, Ohio
wheelsup68dart Offline
Columbus, Ohio
Factory tech here, they all do it to some degree, no problem unless it continues after that first 5 seconds of start up
Re: 2016 Challenger 5.7 engine noise [Re: wheelsup68dart] #2142232
08/28/16 12:56 AM
08/28/16 12:56 AM
dracut mass usa
sparcy Offline
sparcy  Offline
dracut mass usa
have a brand new shaker also , it makes noise , some times i think its worse than other times . IF it BLOWS UP !!!!!! I will put a bigger engine in . my car has 3800 miles on it . I owned mine a hour , and put 69 r/t badges on it .
IF YOU ARE NOT WRECKING STUFF YOU ARE NOT LEARNING !
Re: 2016 Challenger 5.7 engine noise [Re: cudascooter] #2142782
08/28/16 10:48 PM
08/28/16 10:48 PM
acworth / N. georgia - south e...
cheapstreetdustr Offline
my truck does it..all the time at start up.
lately its starting to sound like an header leak.
67k
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
Re: 2016 Challenger 5.7 engine noise [Re: cudascooter] #2142828
08/28/16 11:51 PM
08/28/16 11:51 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
They do have broken exhaust manifold bolt problems thanks to the heat shields.
Re: 2016 Challenger 5.7 engine noise [Re: 72Swinger] #2143410
08/29/16 10:10 PM
08/29/16 10:10 PM
dogdays Offline
dogdays  Offline
Pretty basically EVERY oil filter out there has an anti-drainback valve. So saying you will buy a filter with such a valve is no different than saying you are going to buy a filter.
There may be some specialty filters that don't have the check valve but they aren't sold for regular automotive use at your local Autozone or whatever.
I don't think there's any doubt that the Mobil 1 filter is the best filter out there. It is possible that Amsoil or another smaller manufacturer has an equal. But the Mobil 1 has the best filtering media, using synthetic fibers that allow a much tighter control over pore size.
I recently ran across a clearance sale on Wix filters for my daily driver and I'll use them until they're gone, which could be years.
It's really too bad that Walmart blew out the Purolater line earlier this year, as that was a very nice cheap filter.
The Motorcraft and AC filters are right up there with the best cellulose filters.
But any decent filter has a reliable anti drainback valve. The only way to tell if your particular filter is malfunctioning is to watch your oil pressure on startup.
R.
Re: 2016 Challenger 5.7 engine noise [Re: cudascooter] #2143477
08/29/16 11:20 PM
08/29/16 11:20 PM
Topeka Kansas
K
ksj Online content
ksj  Online Content
K
Topeka Kansas
Wix now has a filter out specifically for synthetic oils
