Header temp #214122
02/04/09 04:39 PM
02/04/09 04:39 PM
nc
E
emarine01 Offline OP
E
nc
Hey what kind of header temps with a infra red gun are you guys seeing , engine warm @ idle , hottest point on header?
Re: Header temp [Re: emarine01] #214123
02/04/09 04:57 PM
02/04/09 04:57 PM
michigan
tonycpe Offline
tonycpe  Offline
michigan
385 to 395 degrees if I remember corectly
QC coatings coated em pretty nice.
Old Fogey Racing Ltd.
Re: Header temp [Re: tonycpe] #214124
02/04/09 05:04 PM
02/04/09 05:04 PM
nc
E
E
nc
Thats a good point , I forgot about header coatings, we are not coated and ave temp is around 500F
Re: Header temp [Re: emarine01] #214125
02/04/09 05:19 PM
02/04/09 05:19 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
im usually around 500 without coating
Re: Header temp [Re: emarine01] #214126
02/04/09 06:54 PM
02/04/09 06:54 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
i would not think a gun could read a fully warmed engine exhaust.i just have an EGT that reads 1320+/- after a run aqt idle.i think a gun goes to 900F.
Re: Header temp [Re: blownzoom440] #214127
02/04/09 07:17 PM
02/04/09 07:17 PM
nc
E
E
nc
My gun reads to 999 , egt would be lots higher than infra red ,egt is in the path of the exhaust , infra red is outside jacket , egt is the way to go for real #s but for the rest of us infra red will have to do
Re: Header temp [Re: emarine01] #214128
02/05/09 12:51 AM
02/05/09 12:51 AM
Cab_Burge Online work
Cab_Burge  Online Work
EGT at idle versus header temps at idle below 1100 RPM will be a bunch lower than 1000 F, or they should be. Running the motor at or above 1200 RPM will make both temps go up
Re: Header temp [Re: Cab_Burge] #214129
02/05/09 05:52 AM
02/05/09 05:52 AM
ELYRIA,OH
ELYRIA,OH
that must be my problem.i have high idle.
emarine01are you thinking of wrapping the headers or thinking of other things?how about some pictures it is winter.
Re: Header temp [Re: blownzoom440] #214130
02/05/09 09:19 AM
02/05/09 09:19 AM
nc
E
E
nc
We tryed wraping them but too hard to clean , baked on mud , break out the hammer , I was just wondering what some other header temps were to kinda base line mine , my friend runs a 500 inch pro stock engine and his temps are in the 900s idles at 1800 rpm , we run 12 to 1 so when were not racing we run 93 pump gas to move the truck around , header temps on 93 are 150f lower than racing fuel the 112 must still be burings on the way out , ill try to post some pics but thier not too good
Re: Header temp [Re: emarine01] #214131
02/05/09 06:48 PM
02/05/09 06:48 PM
ELYRIA,OH
ELYRIA,OH
my temps must have to do with my blower.i need to get back out.i only got out 4 times in 2yrs due to upgrades.i am good to go tho.
what is the use of your engine,race street...?
Re: Header temp [Re: emarine01] #214132
02/05/09 07:26 PM
02/05/09 07:26 PM
off the grid
340B5 Offline
340B5  Offline
off the grid
830 to 860 here w/uncoated headers,then go's over 1000 off idle and above.
Yeah, it's got a smallblock.
Re: Header temp [Re: 340B5] #214133
02/06/09 09:51 AM
02/06/09 09:51 AM
nc
E
E
nc
We mud race a w5 small block , the 340 temps are close to what we had with iron j heads on a 392 mid 800F
