Re: Hellcat bare block part#
[Re: MattW]
#2112266
07/18/16 05:44 AM
07/18/16 05:44 AM
Posts: 8,857 poplar bluff mo.
toplescuda
I Whine
I Whine
poplar bluff mo.
On the Hellcat fourm (not face book) there was a 30 min vid showing all the differences from the he'll cat motor and 392 or 6.1. Was pretty cool. And there is a lot of interesting facts in it.....and it from fca
1970 barracuda convert. 1 of 59 1970 pro street A.A.R. clone (panther pink) 1971 charger 2015 hellcat challenger. Redline red 2014 quad cab 4x4 ram 8 speed hemi
[Re: MattW]
#2116283
07/23/16 07:37 PM
07/23/16 07:37 PM
Posts: 361 Canada
onig
Canada
Hey Matt, did you order it in Canada or the US.
69 Dart
[Re: onig]
#2116318
07/23/16 08:58 PM
07/23/16 08:58 PM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
Hey Matt, did you order it in Canada or the US. What do you think! Lol. Over here its close to 2900.00 before taxes. My guy I get parts from is now working out of Potsdam NY So it's a little longer drive. I don't know if I will get one. Time will tell. On a side note do you know a company called Dark Night. They are on kijiji claiming to be able to tune Mopars. Hp tuners etc.... Want to know if they are any good. Supposed to be around Kitchener On. Thx Matt
[Re: MattW]
#2117015
07/25/16 01:19 AM
07/25/16 01:19 AM
Posts: 361 Canada
onig
Canada
Thanks Matt. I never heard of Dark Night, sorry. I will be using MegaSquirt.
69 Dart
[Re: Supercuda]
#2138320
08/22/16 01:22 AM
08/22/16 01:22 AM
Posts: 486 IL
knyech1
IL
My understanding is that the Hellcat block has cooling jacket changes compared to any other block, aside from machining issues. Quick way to tell right off the bat is to look at the external main web reinforcement on the hellcat vs any other G3 block. I have a pic if needed.
knyech1-
'71 Sassy Grass Demon 340/904. Pump gas, 1.61 60ft, 7.439 1/8 @ 95mph, 11.824 1/4 @ 111mph
"Not too bad for a pump gas 340, full of used parts and hillbilly ported stock heads." - V.B.
'03 2500 5.9L HO 6-spd on 35's. 395hp/755ft-lb at tires.
[Re: knyech1]
#2138637
08/22/16 03:32 PM
08/22/16 03:32 PM
MattW
Ontario Canada
My understanding is that the Hellcat block has cooling jacket changes compared to any other block, aside from machining issues. Quick way to tell right off the bat is to look at the external main web reinforcement on the hellcat vs any other G3 block. I have a pic if needed. Post away with pictures. Would love to know what I'm buying. Matt
[Re: MattW]
#2138885
08/22/16 08:52 PM
08/22/16 08:52 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Sonic numbers is what i'd like to see.
Mopar to the bone!!!
[Re: MattW]
#2184197
10/27/16 10:55 PM
10/27/16 10:55 PM
72Swinger
Nebraska
IIRC that is like 15 lbs heavier than a 6.1 block.
[Re: cudadoug]
#2184675
10/28/16 04:47 PM
10/28/16 04:47 PM
MattW
Ontario Canada
Will all 5.7/6.1/6.4 external parts bolt up? Ex: Front cover, oil pump, intake, etc??
Intake will be different, no? As it's drilled for the blower?? Yes most stuff will. My understanding is that there are two variants of the late model hemi. 5.7 early and 6.1 all stuff will interchange to a degree. late 5.7 , 6.2 and 6.4 same thing. Early and late model timing cover will NOT. Crankshaft do but the later ones need the snout machined to fit earlier blocks. early and late camshafts do not. Hellcat heads need to be drilled as they are drilled differently for the blower. Want to avoid this buy the 6.4 truck heads. Same casting as the hellcat. Matt
[Re: BIGGERED]
#2186037
10/30/16 06:50 PM
10/30/16 06:50 PM
MattW
Ontario Canada
Late Model?
2009+ ...?
Thank you!
Red Yes, but i believe the 6.1 went to 2011. If so then that won't work. Any engine with the VVT is considered late model to me. 5.7 6.2 and 6.4. Matt
