Re: Mikey`s Mopar 470 on the pump.............GUESSES?
[Re: BobR]
#2142912
08/29/16 02:37 AM
08/29/16 02:37 AM
Posts: 1,608 fresno ca
mikeysmopars
fresno ca
OK a few test results from this weekend. First the place was packed, very surprised the pits so full, unloaded went to tech and found out my belts were a month out of date . Got that fixed & went to get the first run with front shocks set about neutral.didnt set the twostep so it didn't leave real hard but ran a 9.95 with 1.46 60 ft @ 135. Only got two runs Saturday so I adjusted front shocks a little looser.checked plugs was a little lean looking changed jets from 92 to 96 made second run around 1:30 and was hot, air was 2700 second run it went 9.89@135 and the 60 came up to 1.42 day was over for us so I changes high speed bleeds,adjusted shocks again and changed chip in launch from 3000 to 3400 and went to Sunday eliminations.launched and watched the other guy and never noticed I went red so I was way out on him and lifted.got my time slip and went 9.89 @122 With 1.38 60 but felt like its leaving soft. Not a bad outing considering that's the first time I've been in my car in almost a year and everything is new.there is a lot left in it but only three runs so I need a good TNT to get it sorted. That last run it went 6.22 in the eighth so I'm gaining. Going back the 16 th next month so I'll hopefully have a few more runs.
Founder and CEO of the Central Valley Mopar Drag Pack
[Re: mikeysmopars]
#2143120
08/29/16 01:21 PM
08/29/16 01:21 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
Just shake down runs and you`ve change just about everything on your car so back to square one. In the vid I saw it wasn't transferring weight and spun a bit so test, test and test some more Mike and you`ll get it.............. Lookin at that slip again, I`d bet you were on a 9.60-70 pass only going 122............
[Re: Thumperdart]
#2143292
08/29/16 07:28 PM
08/29/16 07:28 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
Good job Mike I'm glad it came together for you.. and already is faster then it was before.. these bricks that we drive are hard to make go fast.. trust me I know . I'm happy if it goes home in one piece.lol keep picking away at it..
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: Sport440]
#2143601
08/30/16 01:56 AM
08/30/16 01:56 AM
mikeysmopars
fresno ca
Thanks everyone, going back in a couple weeks, first time with coil over front end and double adjustable shocks. Didn't get all I wanted but happy I had no issues with all I changed and did get a personal best. Hopefully I'll get more than three runs.
[Re: Al_Alguire]
#2143889
08/30/16 02:36 PM
08/30/16 02:36 PM
Posts: 8,282 fredericksburg,va
cudaman1969
fredericksburg,va
Not trying to poopoo numbers here. A question was asked and I gave my answer. Generally depending on the dyno and it water tower capacity or where the water comes from they try not to get them to hot. It may take too long to cool down between runs. The dyno this engine was done on from my experience is not a happy dyno by any means. Generally you can out the ole moroso slide rule to the numbers and have a good idea what an engine off of the Pettis dyno will run in the car. Once the car combination is optimized.
Yes it is true you can make a dyno pretty much spit out inflated corrected numbers. That's great for the dyno crowd. Thus why I always say I want to see a quantifiable result from any dyno when it comes to actual ET's. It is pretty standard practice industry wide to make the last pull with things cool off as much as reasonably possible. It does not mena you get 40 more HP buy any means. You will generally see a gain but it aint gonna move that much. Oil temps and water temps are always monitored, or at least shold beon the Dyno.
My engine that was just on the dyno it was hard to get water temps up very high. The reason being the facility uses a city water connection on the dyno. So they have and endless stream of cold wate at their disposal. Just a matter of running the water pump for a few minutes to get the engine temps down. The dyno we used is notoriously stingy for the numbers it kicks out. It is a new DTS/Superflow unit with a state of the art no expense spared dyno room. It has been pretty consistently down on power from where we used to use. And that dyno was considered stingy by some and honest by many. Numbers usually went dead on to the moroso wheel from the old one.
Interesting what you said, I had a 499 that Kenny L built when he was with McCandless. 15.19 compression Indy head, long story short engine ran hot then finally got temp down to leave at 160 degrees, lost a tenth and one haft. Called Kenny, was told that engine had to leave at 200 degrees to build heat in the heads?? Did that and ran the good number again. A little confusing when some say run it cold and some say run it hot??
[Re: Thumperdart]
#2144057
08/30/16 07:07 PM
08/30/16 07:07 PM
Posts: 3,210 robin hood country
deaks
robin hood country
Nice first outing, i'm suprised you didn't run it all out after you went red though. Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: Cab_Burge]
#2144195
08/30/16 10:45 PM
08/30/16 10:45 PM
cudaman1969
fredericksburg,va
Mopars are not Chebbys or Furds Many misleading myths on what works best on our cars Yes, many misleading myths,
[Re: Thumperdart]
#2144395
08/31/16 06:28 AM
08/31/16 06:28 AM
Posts: 3,667 Arizona
Chris'sBarracuda
Arizona
Just shake down runs and you`ve change just about everything on your car so back to square one. In the vid I saw it wasn't transferring weight and spun a bit so test, test and test some more Mike and you`ll get it.............. Lookin at that slip again, I`d bet you were on a 9.60-70 pass only going 122............ Look again.. More like a 9.82.. Chris.
[Re: Chris'sBarracuda]
#2144514
08/31/16 12:18 PM
08/31/16 12:18 PM
deaks
robin hood country
Just shake down runs and you`ve change just about everything on your car so back to square one. In the vid I saw it wasn't transferring weight and spun a bit so test, test and test some more Mike and you`ll get it.............. Lookin at that slip again, I`d bet you were on a 9.60-70 pass only going 122............ Look again.. More like a 9.82.. Chris. I agree but i'm sure in cooler weather and a bit more tuning a 70 is achievable. Mick
#2144535
08/31/16 01:04 PM
08/31/16 01:04 PM
Thumperdart
State of confusion
Just shake down runs and you`ve change just about everything on your car so back to square one. In the vid I saw it wasn't transferring weight and spun a bit so test, test and test some more Mike and you`ll get it.............. Lookin at that slip again, I`d bet you were on a 9.60-70 pass only going 122............ Look again.. More like a 9.82.. Chris. YOU look again...........he went 9.89 at 135+ then 9.89 at 122........what don`t you get.............
[Re: Thumperdart]
#2144537
08/31/16 01:12 PM
08/31/16 01:12 PM
Posts: 20,180 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Just shake down runs and you`ve change just about everything on your car so back to square one. In the vid I saw it wasn't transferring weight and spun a bit so test, test and test some more Mike and you`ll get it.............. Lookin at that slip again, I`d bet you were on a 9.60-70 pass only going 122............ Look again.. More like a 9.82.. Chris. YOU look again...........he went 9.89 at 135+ then 9.89 at 122........what don`t you get............. Calculate it off the 1000 foot data.
[Re: pittsburghracer]
#2144539
08/31/16 01:18 PM
08/31/16 01:18 PM
Thumperdart
State of confusion
No clue on that but I scrubbed 10+ mph and lost a chunk of et but don`t remember exactly how much. Plus as I told Mikey and was correct in that the dyno tune would be off and it is. Jason had the mixture screws 3/4 out and it ran bad till he brought em out to 1 1/2 where I had em and it wants more jet as expected also. Dynos are a tool and a way to see if our junk leaks and set BASIC starting points that`s it imo...........That car will go easy 9.60`s or better.............
[Re: Thumperdart]
#2144569
08/31/16 02:18 PM
08/31/16 02:18 PM
Triple Threat
Renton Washington
Thumper, If we look at the 1000 foot numbers on his full run where he didn't lift it took him 1.649 seconds to go from 1000 to 1320 under power.
If we take the 1000 foot time on the run where he lifted and add the "known" split time from 1000-1320 the car was going to run about 9.82 as indicated above.
Full pass 9.897 to 1320 8.248 to 1000
9.897 - 8.248 = 1.649 seconds
Lifted pass it was 8.171 to 1000
8.171 + 1.649 = 9.820
No one is doubting the car has the ability to run in the 60's, but it wasn't going to do it on that run.
[Re: Triple Threat]
#2144615
08/31/16 03:27 PM
08/31/16 03:27 PM
Thumperdart
State of confusion
Cool...........I know the math is pretty close but scrubbing 13+ mph just doesn't calculate in my brain............
