new serpentine belt kit with electric water pump drive #2135070
08/17/16 12:59 PM
08/17/16 12:59 PM
Warren, MI
Jerry Offline OP
Jerry  Offline OP
Warren, MI
I started this in the tech section but figured racers may be more interested in this since its got the electric water pump drive....
specs on the kit as shown
coil mount
155 amp alternator
sanden ac compressor
spring loaded tensioner
zf light weight power steering pump
billet pulleys
(no mechanical fuel pump)
kits will start at $750.00
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: new serpentine belt kit with electric water pump drive [Re: Jerry] #2135122
08/17/16 02:29 PM
08/17/16 02:29 PM
It's Complicated
HDNMOPERS Offline
HDNMOPERS  Offline
It's Complicated
Very nice and clean. Do you have a serpentine drive set up like this for mech w/pump with the same low mount a/c comp. Street cruiser would prefer mech w/pump. Thanks
Re: new serpentine belt kit with electric water pump drive [Re: HDNMOPERS] #2135124
08/17/16 02:33 PM
08/17/16 02:33 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
iagree up
Re: new serpentine belt kit with electric water pump drive [Re: Jerry] #2135160
08/17/16 03:14 PM
08/17/16 03:14 PM
Warren, MI
Jerry Offline OP
Jerry  Offline OP
Warren, MI
yes we can do that but you lose the coil mount up top. I can get it mocked up and get some pics up tomorrow. just for reference this was a one off kit for a new customer. when we do stuff like this it takes about 4-8 weeks. this was done in 3 so he can go to the dream cruise. we retain the rights to all design work and can now offer the kit for sale to everyone else. so don't be shy asking if we can do something. we've either done it, or can do it, or will do it. the more people that ask, the higher our priority for various kits.
2574 Elliott Dr
Troy MI 48083
www.sdconcepts.com
www.bcrproducts.com
Re: new serpentine belt kit with electric water pump drive [Re: Jerry] #2135379
08/17/16 08:51 PM
08/17/16 08:51 PM
It's Complicated
HDNMOPERS Offline
HDNMOPERS  Offline
It's Complicated
Yeah. Definitely like to see some pics with mech w/p. No coil bracket no problem. If it looks as clean as the one posted. I would be interested in one.
Re: new serpentine belt kit with electric water pump drive [Re: Jerry] #2135435
08/17/16 10:17 PM
08/17/16 10:17 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Ummm, how is that going to work with a spring loaded tensioner on the load side of the belt?
Belt routing will need to go:
Crank to PS
PS to alt
alt to idler
idler to compressor
compressor to tensioner
tensioner to crank.
The way it is in the pic will throw the belt the first time you whack the throttle.
