Re: new serpentine belt kit with electric water pump drive
[Re: Jerry]
#2135379
08/17/16 08:51 PM
08/17/16 08:51 PM
Posts: 150 It's Complicated
HDNMOPERS
It's Complicated
Yeah. Definitely like to see some pics with mech w/p. No coil bracket no problem. If it looks as clean as the one posted. I would be interested in one.
[Re: Jerry]
#2135435
08/17/16 10:17 PM
08/17/16 10:17 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
Ummm, how is that going to work with a spring loaded tensioner on the load side of the belt? Belt routing will need to go: Crank to PS PS to alt alt to idler idler to compressor compressor to tensioner tensioner to crank. The way it is in the pic will throw the belt the first time you whack the throttle.
