Re: Anyone use a hilborn injection setup yet
[Re: biff426]
#2133158
08/15/16 12:26 AM
08/15/16 12:26 AM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
No input but would love to see pics
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: biff426]
#2133243
08/15/16 02:25 AM
08/15/16 02:25 AM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Uchoog on here has an EFI version.
Mopar to the bone!!!
[Re: biff426]
#2134026
08/16/16 12:52 AM
08/16/16 12:52 AM
Posts: 1,938 Sonora CA
Mopar_Rich
Sonora CA
I was thinking of using the mechanical old school setup On alky okay, but mechanical systems on the street never run well on gas.
[Re: GTS340]
#2134272
08/16/16 12:39 PM
08/16/16 12:39 PM
Posts: 723 Houston Tx
Uhcoog1
Houston Tx
This is me. Good picture find, GTS340! Yes, I'm running it as EFI. It's quite easy to tune on the MS3x. ITB's make for easy tuning with large camshafts (though my current cam is small around 235/239 @ .050). Alex's 6.1 is much harder to get to idle. Is there anything specific you would like to know, Biff? The motor is out right now. I would entertain offers for the Hilborn, if you're interested. The purpose and theme of the car is changing, so I'm considering induction changes as well.
-'02 Dodge Viper Ex-World Challenge racecar -'73 Duster, 6.1 based 392 hilborn hemi, tko600, full floater rear 9", Hellwig custom bars, viper brakes, built for road course
[Re: biff426]
#2134707
08/16/16 09:57 PM
08/16/16 09:57 PM
72Swinger
Nebraska
Borla and Hilborn both sell them for the G3's.
[Re: biff426]
#2134777
08/16/16 10:56 PM
08/16/16 10:56 PM
Uhcoog1
Houston Tx
Uhcoog I sent you a PM what are you using for a fuel pump/regulator? Do you have any dyno numbers or track numbers? 415 rwhp at 6800 rpm on a 348ci on a mustang dyno (stock 6.4 challenger with bolt ons did 402 on same dyno). With a baby 218/224 @ .050 cam. Current fuel pump is walbro 460 lph in-tank Previous fuel system was walbro gsl392 fed by accumulator and carter low pressure pump using a factory tank. Both times I used a wix 33737 filter/regulator and deadheaded the fuel system
[Re: biff426]
#2135553
08/18/16 12:35 AM
08/18/16 12:35 AM
sixpackgut
Charleston
Im sure it would be expensive, but has anyone experimented with the tube lenghts and how much would it effect rpm range, torque and hp
