Anyone use a hilborn injection setup yet #2133146
08/15/16 12:17 AM
08/15/16 12:17 AM
Deland, Florida
biff426 Offline OP
biff426  Offline OP
Deland, Florida
I am building a 65 Coronet that I was going to race in Nostalgia Super Stock. With the current block situation for gen 2 Hemis and Big Blocks I am having second thoughts and am now thinking of doing another retro looking gen 3 and just racing a 10.0 class with it. I have been checking out the Hilborn deal has anyone used one looks like they have a EFI version and a mechanical version. Any input is welcome.
Re: Anyone use a hilborn injection setup yet [Re: biff426] #2133158
08/15/16 12:26 AM
08/15/16 12:26 AM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
No input but would love to see pics
Re: Anyone use a hilborn injection setup yet [Re: biff426] #2133243
08/15/16 02:25 AM
08/15/16 02:25 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Uchoog on here has an EFI version.
Mopar to the bone!!!
Re: Anyone use a hilborn injection setup yet [Re: 72Swinger] #2133344
08/15/16 10:24 AM
08/15/16 10:24 AM
Romulus, MI
GTS340 Offline
GTS340  Offline
Romulus, MI
Re: Anyone use a hilborn injection setup yet [Re: biff426] #2133989
08/16/16 12:08 AM
08/16/16 12:08 AM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
Done several and they work very well as long as they are setup for EFI. What I mean is that individual lines are run to a vacuum accumulator block so you get a good map signal (note the lines on the picture). You must run sequential injection but that's normal with a Gen III because you have a cam signal. I can post pics if you want but there's real no drama.
Both Holley and Fast offer plug and play kits now.
Re: Anyone use a hilborn injection setup yet [Re: Mopar_Rich] #2133999
08/16/16 12:17 AM
08/16/16 12:17 AM
Deland, Florida
biff426 Offline OP
biff426  Offline OP
Deland, Florida
I was thinking of using the mechanical old school setup
Re: Anyone use a hilborn injection setup yet [Re: biff426] #2134026
08/16/16 12:52 AM
08/16/16 12:52 AM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
On alky okay, but mechanical systems on the street never run well on gas.
Re: Anyone use a hilborn injection setup yet [Re: GTS340] #2134272
08/16/16 12:39 PM
08/16/16 12:39 PM
Houston Tx
Uhcoog1 Offline
Uhcoog1  Offline
Houston Tx
Originally Posted By GTS340
This is me. Good picture find, GTS340!
Yes, I'm running it as EFI. It's quite easy to tune on the MS3x. ITB's make for easy tuning with large camshafts (though my current cam is small around 235/239 @ .050). Alex's 6.1 is much harder to get to idle.
Is there anything specific you would like to know, Biff?
The motor is out right now. I would entertain offers for the Hilborn, if you're interested. The purpose and theme of the car is changing, so I'm considering induction changes as well.
-'02 Dodge Viper Ex-World Challenge racecar
-'73 Duster, 6.1 based 392 hilborn hemi, tko600, full floater rear 9", Hellwig custom bars, viper brakes, built for road course
Re: Anyone use a hilborn injection setup yet [Re: Uhcoog1] #2134691
08/16/16 09:36 PM
08/16/16 09:36 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Where would one look for a set up like this?
Re: Anyone use a hilborn injection setup yet [Re: Uhcoog1] #2134700
08/16/16 09:47 PM
08/16/16 09:47 PM
Deland, Florida
biff426 Offline OP
biff426  Offline OP
Deland, Florida
Uhcoog I sent you a PM what are you using for a fuel pump/regulator? Do you have any dyno numbers or track numbers?
Re: Anyone use a hilborn injection setup yet [Re: biff426] #2134707
08/16/16 09:57 PM
08/16/16 09:57 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Borla and Hilborn both sell them for the G3's.
Re: Anyone use a hilborn injection setup yet [Re: biff426] #2134777
08/16/16 10:56 PM
08/16/16 10:56 PM
Houston Tx
Uhcoog1 Offline
Uhcoog1  Offline
Houston Tx
415 rwhp at 6800 rpm on a 348ci on a mustang dyno (stock 6.4 challenger with bolt ons did 402 on same dyno). With a baby 218/224 @ .050 cam.
Current fuel pump is walbro 460 lph in-tank
Previous fuel system was walbro gsl392 fed by accumulator and carter low pressure pump using a factory tank.
Both times I used a wix 33737 filter/regulator and deadheaded the fuel system
Re: Anyone use a hilborn injection setup yet [Re: biff426] #2135553
08/18/16 12:35 AM
08/18/16 12:35 AM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
Im sure it would be expensive, but has anyone experimented with the tube lenghts and how much would it effect rpm range, torque and hp
