Re: 68 Charger cruise stumble - AVS carb question [Re: 70mopes] #2131275
08/12/16 05:17 PM
08/12/16 05:17 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
A friend used to work at a local dealer, he specialized in tuneup/driveability. A lot of stock AVS's would have a lean surge at light throttle, his fix was to drill out the idle feed tube in the primary venturi cluster (this is the smaller of the two brass tubes that extend into the carb body).
The hole in the tube is very small, takes a miniature drill set to enlarge the opening a couple of drill sizes. Worked for me.
Another thing to check is the fit of the primary throttle shafts in the main body, simply wiggling the throttle lever around can cause the idle speed to change noticeably if the shaft is loose and causing a vacuum leak around the shaft....also causes a lean surge.
Re: 68 Charger cruise stumble - AVS carb question [Re: 70mopes] #2131437
08/12/16 08:38 PM
08/12/16 08:38 PM
Niwot, CO Formerly denn...
dynorad Offline
dynorad  Offline
You might check to ensure the throttle blades are closed enough at idle to get a good signal to the idle circuit.
Re: 68 Charger cruise stumble - AVS carb question [Re: 70mopes] #2131511
08/12/16 09:57 PM
08/12/16 09:57 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
68 carb?
Abe Lincoln
Re: 68 Charger cruise stumble - AVS carb question [Re: 70mopes] #2133409
08/15/16 12:06 PM
08/15/16 12:06 PM
Maple Valley, WA
70mopes Offline OP
70mopes  Offline OP
Maple Valley, WA
Yes. 68 Carb.
Tried drilling out the idle tube on the venture cluster - no change
Tried a different set of venturi clusters (with more holes in the emulsifier tubes (large tubes) and it ran to lean and would not idle worth a darn.
Installed different needles...slightly smaller and it still had the problem but ran a bit fatter.
Checked vacuum tree connections to make sure not vac. loss (OK)
Set floats to spec.
Car runs good in most every aspect. Good power, barks first to second however right at 35 MPH it hunts.... not really a stumble but hunts like a carb circuit transition issue.
If it was ignition, I would expect to feel it elsewhere in the powerband. Vacuum advance is working correctly. I set the can to lighten up the diaphragm and that did not make any difference.
Re: 68 Charger cruise stumble - AVS carb question [Re: 70mopes] #2133456
08/15/16 12:52 PM
08/15/16 12:52 PM
pull the vac adv can hose & plug it & retry it
Re: 68 Charger cruise stumble - AVS carb question [Re: 70mopes] #2133595
08/15/16 03:50 PM
08/15/16 03:50 PM
Glendale, AZ
69L78Nova Offline
Banned. Forever.
69L78Nova  Offline
Banned. Forever.
Glendale, AZ
Have you even bothered to check the operation of the hot idle compensator valve like I suggested earlier?
1969 Nova
454/M21/3.31
Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD
5.0/4R70W/3.55
(Daily driver)
Re: 68 Charger cruise stumble - AVS carb question [Re: 70mopes] #2133671
08/15/16 05:22 PM
08/15/16 05:22 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Carb does not have a compensator valve.
Re: 68 Charger cruise stumble - AVS carb question [Re: 70mopes] #2134269
08/16/16 12:37 PM
08/16/16 12:37 PM
Maple Valley, WA
70mopes Offline OP
70mopes  Offline OP
Maple Valley, WA
Was dinkin with the car again last night. Playing with vacuum advance and test driving. It behaved a bit better at cruise with the vac advance blocked but, there was an off idle stumble that popped up. In frustration and thinking vacuum leak somewhere, I sprayed a bunch of carb cleaner along the head to intake interfaces. I got some stumbles when spraying at the intake runners but when I sprayed the area around the heat crossover.... on both sides... the car would stumble badly and almost die. In fact I could have caused it to die if I would have kept on the spray a few seconds. The affect was far greater at this location than around the intake ports themselves.
I thought the crossover was a closed chamber between each side of the manifold? I was surprised that area had such a large affect when checking for leaks. I will be pulling the intake obviously but does anyone have any ideas at this point as to why this situation is occurring?
Thanks again to all for your feedback.
Side note:
The intake crossover on the driver side has the paint burned quite a bit more than the passenger side crossover. Not sure that indicates anything....
Re: 68 Charger cruise stumble - AVS carb question [Re: 70mopes] #2134350
08/16/16 02:17 PM
08/16/16 02:17 PM
with the can capped making it better you might check Rotor Phasing (my baby) and also total timing at the RPM where the problem is. yes the center heat riser openings ain't an intake port as you know but if the intake is warped enough or the gasket is bad it could be pulling a vac leak in at that point which it definitely sounds like it is doing, just make sure that the spray did not get pulled into the nearby carb airhorn or carb base & give a false symptom. not likely but pulling the intake is work & it never hurts to keep Mr Murphy at bay. I use a piece of cardboard to keep things isolated when testing. yes pull the intake & go from there
Re: 68 Charger cruise stumble - AVS carb question [Re: 70mopes] #2134369
08/16/16 02:40 PM
08/16/16 02:40 PM
Maple Valley, WA
70mopes Offline OP
70mopes  Offline OP
Maple Valley, WA
It was sprayed directly at cross over from short range and it would just fall flat on its face. I have to wonder, as bad as that area appears to be leaking and the fact that it is somewhat displaced from neighboring intake interfaces, how is that spray entering the intake at that point - enough to make it stop running?
I will find out soon enough. Gasket is either totally shot (only a couple thousand miles on the motor), manifold to head interface is bad or possibly a crack in the intake allowing crossover gasses to enter the intake plenum? Has anyone ever heard of such a thing ever happening? thinking out loud.
Re: 68 Charger cruise stumble - AVS carb question [Re: 70mopes] #2134376
08/16/16 02:44 PM
08/16/16 02:44 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
Originally Posted By 70mopes
Great tips fellas. Thanks.
I had the AVS apart yesterday, before reaching out on moparts. I cleaned up the pistons but not the bores in the carb. The metering rod on the passenger side was worn bad and the spring holding it was out of position and off the rod. I used a set of rods out of a 4429S. I also adjusted the floats to parallel with the top to increase the amount of fuel in the bowls. Overall that whole process seemed to richen the whole shebang up ... which is what I would expect. I adjusted the secondary air horn since I was getting a bog and smoke when matting the pedal.
The air/mixture screws are adjusted very far out. More than they should be in my opinion. When screwed all the way in and adjusted 1 1/2 turns out, the engine won't even start. I figured adjusting the float level and cleaning the emulsification tubes etc, along with fixing the needle/piston would make things better. If anything I am a bit worse with the same hunting problem and now and enrichment problem when throttling up.
I need to mention also that this is an original carb that has the single air bleed in the center top but now also has the two mixture screws in the bottom as well. Also, The emulsification tubes in the carb have only 4 small holes each. That indicates to me that the engine should be pulling a solid fuel mix to the idle circuit slots/holes. I am confused as to why it takes so much outward adjustment to get it to idle right.
I will follow up on the tips provided. any other insight would be appreciated.
backing the mixture screws out a lot with no big differences in idle quality indicates the idle jets are too small. they will need to be opened to at least .035". the 4618s avs i run works best with .037" idle jets. stock for an auto trans car is .031" and .035" for a 4spd.
Re: 68 Charger cruise stumble - AVS carb question [Re: 70mopes] #2134528
08/16/16 06:37 PM
08/16/16 06:37 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Plenty of good carb tuning tips in this thread, so I won't offer anything about that, but I will add that when I mill the intake side of those nearly 50 year old heads and intake manifolds......... They are always far from being flat.
