Re: 318 pullys will the line up with a 360.
[Re: 69L78Nova]
#2132469
08/14/16 02:59 AM
08/14/16 02:59 AM
RapidRobert
mancini & 440 source has crank shims & speedway mtrs & others have pump shims. spacing the alt is easy. the pump "cross" can move in or out a slight bit. use a piece of tubing or a laser pointer in a pulley groove to confirm dead on alignment if in doubt or in a high RPM app
[Re: Dons Dart]
#2132484
08/14/16 03:46 AM
08/14/16 03:46 AM
Posts: 9,826 las vegas
70AARcuda
las vegas
they will line up just fine...
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
